12-06-2018, 03:16 PM | #1 |
@blackout__ss on insta
Drives: 2018 Camaro 2ss Join Date: Aug 2018
17" wheels
Hi everyone, I am interested in buying a set of 17" GTO wheels that are 245/45/17... Does anyone know if they will fit?
12-07-2018, 02:34 AM | #2 |
Drives: 18 zl1 Join Date: Aug 2017
on the front:
tires will be almost an inch closer to suspension. rims will be almost 3/4" closer to suspension components. the offset puts the brakes closer to the rim, so fitment there may be too close, if not contacting. on the rear: everything should clear like stock except for brakes, you'll run into the same issue as the fronts; the brakes will be closer to the inside of the rim, and may contact. this is based off of stock gto 17" rims/tires, and stock ss non 1le 20" rims/tires |
