11-27-2018, 02:17 PM | #1 |
Drives: 16 1SS M6 Black -previous 00 Z28 M6 Join Date: Oct 2018
Anyone Use Ammo Frothe
Thinking about getting it but want to know its real world results. Live in an apartment and they shut down the hose at our designated car wash station from Nov-Mar, and not many brushless washes around, so this may be the best solution.
11-27-2018, 07:40 PM | #2 |
I just used it for the first time for the final, hoseless wash before putting the car to sleep. It's a good product, cleans thoroughly, better than the regular Adam's shampoo or waterless wash, not sure about this one vs Adam's rinseless. It certainly foams very well and wipes off with little to no resistance.
Yet I am not blown away like I had expected, did everything by the recommendation and the small slivers of remaining product dried to a faint sheen against the ceramic that I then had to wipe off a bit more intensely, and, of course, swirl marks were the result, despite using an army of new soft MF towels. Not very bad, they will probably polish off, but I had hoped to avoid this. (Frankly, if I had known the clear would be so sensitive, I wouldn't have bothered with the ceramic, but I digress. I'm probably too clumsy.)
11-27-2018, 07:45 PM | #3 |
Gotcha, thank you! I may give it a shot - I typically like ammo products (and I love Larry’s videos) so while not perfect, glad to hear it’s at least effective.
11-28-2018, 09:09 AM | #4 |
Drives: 2018 zl1 1LE Join Date: Mar 2017
I tried it a couple times on my wifes car. I don't hate it but for my money I still prefer ONR.
FWIW I have tried a number of other rinseless products and always come back to ONR.
2018 ZL1 1LE
2021 GLS63 AMG 2005 SRT4 2017 Ram 1500 |
11-28-2018, 09:12 AM | #5 |
Retired from Car mfrs....
Carpro Ech20 is still my favorite. Over the blackfire rinseless, wolfgang, ONR, duragloss, I keep coming back to ECH20.
11-28-2018, 10:12 AM | #6 |
I've never done rinseless before - I assume this isn't a forever solution, right? Do you guys do a normal bucket wash and only go rinseless for the lightly soiled in between washes? Or am I wrong and this can replace the hose and bucket forever?
11-28-2018, 10:19 AM | #7 | |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
Look up the Garry Dean method on YouTube. IMO, the safest, quickest, and most effective method is to use two buckets for the paint. I use a separate bucket and tools for my wheels. For some people this isn't practical or possible though.
11-28-2018, 10:24 AM | #8 | |
http://www.camaro6.com/forums/showthread.php?t=435828 |
11-28-2018, 11:03 AM | #9 | |
Drives: 1SS 1LE Join Date: Mar 2018
To get you by its useful but when you can, 2 buckets and a hose!
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
11-28-2018, 11:14 AM | #10 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
100% on the rinseless, even on dirty cars! Make sure you do it the right way and you will be fine...good quality MF towels, I prefer EcH20, awesome product! The only time I use a hose it when the wheels wells are filty, especially with wet leaves, and to clean up the undercarriage, other than that, hose stays away.
11-28-2018, 01:52 PM | #11 |
Thanks everyone! I have been fairly religious with the two-bucket system, but with a new baby and less hose availability, I needed to venture out a bit for something quicker and more convenient - glad to hear so many people have had good luck with it!
11-29-2018, 01:01 AM | #12 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Rinseless/bucketless wash is fine for normal washes, as long as your technique is sound. You want to sacrifice the first towel (Chemical Guys towel bundles on Amazon FTW) to do a zero pressure soak and lift of any heavy soiling on the car (e.g. bird crap and bugs on the front). After that, never overuse any towel for the main cleaning, which should be done with little to no hand pressure as well. Go one panel at a time. Wet the next panel with your bottle before you start wiping the current panel (allows solution to do its' job to encapsulate dirt and debris). Dry each panel after it is wiped.
Once you've done the low/no pressure cleaning pass, go back to any difficult spots you found and use light to moderate pressure on just those spots. Use a fresh towel for this step as well and only use one spot on the towel for each spot you touch. This keeps the damaging elements you lift from scratching you elsewhere. The paint is done and you should now be able to run your drying towel over all the panels with uniform friction. Again, no pressure. Your hand should feel the smoothness through the towel (put your hand in the folded towel if it is large and allow only one layer between your hand and the paint). If there is no pulling or sudden grip zones, you've done it right. At this point I should mention that I do the glass first and dry the glass again after any overspray from the paint clearing stages. I personally don't care about the barrel of my wheels, so I just wring out the first main pass towel so they are barely moist and lift the brake dust off of the face of the wheels. Since nearly no moisture is left behind, no need to dry these. The towel used on the wheels goes in the trash, because I don't want that stuff in my washing machine eating the drum coating. Again, this isn't a show quality wash system. It is on par with a two bucket method for results and doesn't require breaking out the hose. Bucket soaking the towels has 3gal of water and I use a pair of 16oz spray bottles (because one 32oz bottle is annoyingly bulky). Since towels never go back in, you could recharge the same water on the next wash with the addition of 40% the normal solution mix stirred in, but I wouldn't do it in cooler months as you want your bucket water warm for best results. The biggest thing I enjoy about the method is that I do it in the garage, at any hour, without putting a puddle on the floor. If I were to change to any other methods, it would be an investment. I'd go with either foam cannon or dry stream on factory painted cars and dual filtered, air-injected solution for aftermarket and heavily polished vehicles. With any of those methods, the only time a non-drying towel would touch the car is for emergency detail away from home or when lifting a stubborn spot. |
Thread Tools | |
