Old 10-20-2018, 03:48 PM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yep all of that stuff is adjusted on mine. Shift time, inertia, pressure...etc.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 10-22-2018, 07:32 AM   #16
TJay74
Can you share some suggestions on what to modify on the shift pressure tables? I have the shift times nailed down as of now and got the TCC slip removed as well.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 10-22-2018, 02:46 PM   #17
KingLT1
KingLT1's Avatar
Max pressure KPA needs bumped up along with the base line pressure for TCC on/off. There is a ton of stuff that needs done though so all the changes work together.
2016 NFG 1SS A8
Old 10-23-2018, 10:46 AM   #18
Silverwing
Drives: Yellow 2018 SS
So has anyone actually got completely rid of the shudder via a TCM tune?
I haven't seen anyone say their tune fixed their shudder issue yet, even though some people are claiming it will fix it.
Silverwing is offline   Reply With Quote
Old 10-23-2018, 04:03 PM   #19
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I think you’re missing a key piece of info, and that is: if you’ve experienced the shudder, the torque converter is already slipping and it’s downhill from there. TCM tune will help prevent it from happening to begin with, but it can’t go back in time to fix what was already done...!
Old 10-30-2018, 10:43 AM   #20
Silverwing
That doesn't really align with what info GM has put out. If that were the case you wouldn't see people say their shudder went away, even temporarily, with a fluid change.
Based on the lack of answer though, I would venture to say very little to no one has successfully reprogrammed their TCM and got a fluid change to permanently get ride of the shudder, which is what I want to do.
Guess I'll keep this up and bump occasionally to see if anyone gets this accomplished.
Old 10-30-2018, 10:57 AM   #21
KingLT1
KingLT1's Avatar
Tim Sloper who was a tuner for EFI tuning was the first one to post the tuning fix. He fixed his shudder with tuning. Some have been successful others have had it return. My guess is it depends on how bad of shape the converter is before the tuning is applied.
2016 NFG 1SS A8
Old 10-30-2018, 11:18 AM   #22
Joshinator99
Uh, not sure about you, but waiting for answers from the company that has butchered it for 4 years seems a bit silly. Plus, they want to admit nothing, otherwise everyone will come out of the woodwork looking for warranty work or money.
King’s post is right on IMO. If the torque converter has been shuddering for a while, tuning won’t save it. But if you catch it early, you might be ok after tuning and fluid change. But I stand by my original statement: tuning cannot repair already damaged torque converter clutches.
Old 10-31-2018, 10:52 AM   #23
Silverwing
Well they did say they have a new fix coming in 2019, I agree with the person who said it's probably a reprogramming of the TCM by GM. The time delay is probably due to getting it cleared by the EPA for their MPG ratings.
My shudder is very intermittent. Most days I don't experience it at all and other days, especially hot days or days where I'm driving for an extended period of time, I get it repeatedly, usually in heavier traffic.
I also use the range device to eliminate my V4 mode so that may be why it's so intermittent.
As you can probably tell my shudder is very conditional and judging all this really makes me think my TC is not entirely cooked yet, and a reprogram of the TCM might very well save my transmission.
I think I'm going to wait to see what GM's next step is in 1Q2019 and go from there.
Old 11-20-2018, 12:44 PM   #24
Sweet15
Sweet15's Avatar
Drives: 2018 2SS HBM Vert
For those who are just replacing the TC, what are you using (brand/stall).
Sweet15 is offline   Reply With Quote
Old 12-11-2018, 04:21 PM   #25
SlydrSS305
SlydrSS305's Avatar
Drives: 2016 Camaro SS
I'm sure most are using Circle D the stall depends on your cam/build
Rotofab, PRAY IM/TB, SE 1 7/8 longtubes full system, SM FLEX FUEL KIT, Custom Exhaust, Mishimoto Catch can, FBO, street tuned.
SlydrSS305 is offline   Reply With Quote
Old 12-11-2018, 05:17 PM   #26
tom's2005gto
Drives: 2016 2SS A8 Convertible
FTI 3200
tom's2005gto is offline   Reply With Quote
Old 12-12-2018, 05:02 PM   #27
Kedavis
Drives: 2017 garnet red ss
I purchased FTI 3600 triple disc converter on there black Friday sale. Just pulled tcm and sent it to hp tuners they just emailed me a return tracking and I just shipped it to them Monday. So cudos to hp tuners on the quick turn around. I will post the results,I've had the flush done twice and it good now but like others have said once the damage is done its done. Plus I wanted a stall anyways..lol
Kedavis is offline   Reply With Quote
Old 12-12-2018, 09:03 PM   #28
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
In lieu of the latest news, I've just installing my unlocked TCM from HPT on my 16k mile '18. Any tips on holding gears longer under part throttle KingLT1? Thanks for the other tips here!
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
