Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > ZL1 Parts
Old 09-28-2018, 02:22 PM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
2016-2018 Camaro SS 1LE APR Carbon Fiber Front Splitter
2016-2018 Camaro SS 1LE APR Carbon Fiber Front Splitter $424.15
Check out this 2016-2018 Camaro SS 1LE APR Carbon Fiber Front Splitter. The Camaro 1LE has great handling from the factory but if you track your Camaro you know you can always use more. APR Front Splitters are utilized to give extra traction and control in the front of a car. By creating a high-pressure area on top of the splitter your front tires will be firmly planted allowing you to take corners faster. And as you know faster corners equals faster laps.
Every APR front splitter is manufactured from solid carbon fiber for rigidity and strength under high speeds. This carbon fiber front splitter comes with a clear coat finish, giving it a high luster shine. This finish will match the glossy shine of your Camaros exterior painted panels so your Camaro is sure to be noticed on and off the track.
This splitter comes stainless steel support rods to actually keep the splitter in the front bumper from warping or twisting under high rates of speed due to the increased downforce.
Features:
Carbon Fiber Reinforcement
All APR Front Wind Splitters are reinforced with sheets of carbon fiber.
Fully Functional Undertray
Our Front Wind Splitters are not just add on cosmetic pieces. Every APR Front Wind Splitter completely covers the entire area below a cars front bumper. This allows for smoother air flow below the front bumper, creating more efficient downforce.
Support Rods Included
Supporting every APR Front Wind Splitters are stainless steel support rods.
***All Front Wind Splitter are built to order. Build time is 2 Weeks***
https://www.rpidesigns.com/shop/item...ront-splitter/
RPI Designs is offline   Reply With Quote
Old 03-16-2019, 07:28 PM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
Thank you for the orders! Use coupon code LANA5 to save 5% off your order!
RPIDon is offline   Reply With Quote
Old 10-14-2019, 02:12 PM   #3
RPI Designs
