04-05-2021, 06:53 AM | #1 |
Drives: 2020 Camaro LT1 M6 Join Date: Nov 2020
Tried teaching my girlfriend how to drive manual, broke transmission?
Good morning,
Last week, I attempted to teach my girlfriend how to drive my 6spd LT1. She stalled quite a few times, which I didn't think was a problem because I did too as I was learning. Some of these stalls happened from 3k RPMs, not sure if that will have something to do with it. She was also slamming the car into gear which I corrected quickly, but some damage could have occurred there. When I got back into the driver's seat, I noticed that my shifter is now significantly more difficult to get into any gear. Sometimes it gets better, and after hard shifting, it stiffens up. Anyone have any ideas as to what could be wrong with the car? Debating on taking it to service department. |
04-05-2021, 07:40 AM | #2 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
Unless you have tons of disposable cash, you don't teach someone to drive manual in your new sports car. Your transmission is now fried and I doubt any dealer will repair it under warranty as I am pretty sure they can determine it was driver error which caused the failure upon inspection. Get ready to to pay a very large repair bill. They will most likely need to replace the entire TR6060.
The proper way to teach someone how to drive manual is in an old car or pick up. Used running 5 speed manual Saturn's from the 90s can be had for under $500 bucks. That would have been much cheaper and trouble free for you. Good luck, your going to need it. |
04-05-2021, 07:52 AM | #3 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
What he ^^ said
In the 70's I learned on a old POS, Capri 4-spd. Made all my mistakes on that beater. You could try and see if dealer will fix it under warranty, but I wouldn't get my hopes up. Good Luck |
04-05-2021, 07:53 AM | #4 |
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
Between you and your girlfriend, you may just have killed the clutch. Transmissions can take a fair amount of abuse, but slipping the clutch at 3,000 RPM on a 455 HP car can chew up clutch discs pretty quickly.
Bolt-ons.
04-05-2021, 08:02 AM | #5 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
I am not sure how you can stall a car at 3kRPM. Seems to me she would be doing a burn out. Anyhow, I would think you have more of a clutch problem teaching someone to drive a stick with a dual disc clutch. These tremecs are pretty stout and stalling the car and over revving is hard on the clutch. Did you smell burnt clutch while this was happening. I would start by checking your release point on the clutch pedal, next I would change the trans fluid and check for any metal shavings. When I taught my son I had him in a parking lot and practiced feathering the clutch until he could get the car rolling without gas, then I had him feather the gas until he could hold the rpms steady then put the two together. Now I do have the single disc clutch so it has to be softer than the dual. Next question, unless you are in a logging accident and your left leg is cut off why would you let your girlfriend drive your LT1.
04-05-2021, 08:04 AM | #6 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
Stalling and teaching someone can be hard on a clutch. I'm not sure it would cause serious issues to the tranny itself, how often did you all stall?
Did she learn right after you learned? You'll probably need a new clutch as others stated, hopefully nothing about the transmisison itself.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
04-05-2021, 08:05 AM | #7 |
That's wishful thinking, im sure those plastic shift forks are trashed as well as the synchros on at least 1st and 2nd with tons of fresh metallic shavings from the grinded gears. I'm sure the damage goes beyond that if I had to wager. If the OP just fried the clutch AND only the clutch, that would be miraculous.
04-05-2021, 08:08 AM | #8 |
While we are on the topic, I've been driving stick for years now, but I want to improve - anyone have tips specific to high hp applications like a V8 camaro?
04-05-2021, 08:10 AM | #9 |
Drives: 2016 Camaro 2SS Join Date: Apr 2016
Fluid change
If you are that concerned that there was transmission damage I would change the fluid and check for metal filings or pieces. Drain fluid in a open pan and look for metal, and maybe use magnet.
However, unless you both were overly abusive with grinding gears, I agree with the others that it is likely that the clutch is fried. If so, it is likely the flywheel has burnt spots on it and needs to be resurfaced.
2016 Camaro 2SS, Hyper Blue
2017 Silverado 2018 Mustang Ecoboost, Perf. Pack(current Daily) |
04-05-2021, 08:17 AM | #10 |
Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
The group here in the forum can guess all day long but, your best bet is if the car is still under warranty take it to the dealer an let them look into it. You never know they may cover it under warranty or send you down the road if they feel it is because of abuse, it doesn't hurt to try. Best of luck.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD |
04-05-2021, 08:18 AM | #11 |
Nothing you haven't already learned, don't ride the clutch, keep your left foot off the clutch pedal as often as possible. Pay attention to your wide open throttle 2-3 shift. Power shift at your own risk. Keep your rev match on if you do not have the habit of doing it yourself. Be mindful of your clutch operation while pulling away from a stop when on an incline, etc...
04-05-2021, 08:22 AM | #12 |
I think some of the advice here feels like its from the dark side. I doubt you killed the tranny. A 6060 is a tough unit. Maybe took some life off the clutch. Like mentioned drain the fluid, check for debris and go from there. If you find debris - take it to the dealership and tell them it is hard shifting and go from there. Its easy to become hypersensitive after an uncomfortable issue and then worry about damage. If the gears aren't grinding with the shifts after the fluid change I'd roll with it.
04-05-2021, 08:23 AM | #13 | |
'20 ZL1 1LE A10,
04-05-2021, 08:30 AM | #14 | |
