05-08-2016, 08:06 PM | #29 |
Drives: 2016 2SS Hyper Blue Join Date: Apr 2016
Thanks for pointing that out man. I appreciate it. I re read the install too and you're right, they are very specific on this, being in red and bold and its own step. Hopefully this fixes it. I'm definitely going to ask cai in the cai thread why.
'16 2SS Hyper Blue Metallic - M6 - NPP - MRC -Black bowties - CAI Intake - SW Cat Back w/NPP
Other money pits: '13 S1000RR '11 R1200 GS Adventure '01 HD Sporty 1250 |
05-11-2016, 08:26 PM | #30 |
Drives: 2016 Camaro 1ss Join Date: Apr 2016
update, had the pipes all rewelded and had the code cleared, the engine light came back on the next day. i guess im gonna have the cats put back on and just put some different mufflers on for sound. the performance shop was bewildered that this code keeps coming on, apparently its a "permanent history code" the same thing the dealer said after they cleared the code, idk its weird, only way to get rid of it permanently is to have the rear o2's tuned out, but i dont want to void the warranty, im taking it to the dealer tomorrow for the first oil change and see what they say about it
05-11-2016, 08:44 PM | #31 |
Drives: 2016 Camaro SS Join Date: Jan 2016
The permanent type codes will remain until the ECM verifies the condition is in fact gone. Clearing it with a scan tool will not remove it.
I'd hold off a day or two and see if it goes away. |
05-11-2016, 09:48 PM | #32 |
ya but the code was cleared after the welds were fixed, meaning there was no light, after i drove it for a day it came back on, if the problem was fixed i would assume the light would not come on? idk itll be prob be next week until i could get them put back on anyways, we'll see. but i highly doubt the light would come on, then just turn off?
05-11-2016, 10:15 PM | #33 |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
If the welds are fixed, your o2 sensor in that one bank might be faulty.
05-12-2016, 04:40 PM | #34 |
The shop data logged it and said the o2s are reading fine. Took it to the dealer for oil change and they said the rear o2s are not getting hot enough since the cat is gone and is throwing a code. They also said they would have to void my emissions warranty if I did not put them back. I've done some research as well and other people are having this problem. Not all but some. Few guys chimed in on this thread as well saying it threw a code. Just know it is a possibility that deleting the rear cats can this a code. I'll be putting them back and just adding an outlaw axelback
05-13-2016, 08:00 AM | #35 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
05-13-2016, 08:15 AM | #36 |
They are in front of them. Right behind the primary cats. These newer systems are just really sensitive I guess. No need in voiding my emissions warranty for an extra five horses though. I mainly just did it for sound lol
10-29-2017, 10:57 PM | #37 |
Drives: 2018 Camaro SS 1LE \ 2006 Z06 Join Date: Sep 2017
And here I am, in a 2018 1LE, 1200 miles on the odometer, with the same code and issue. Code popped a few days after 2nd Cat delete, and same day I installed a Mishimoto catch can.
11-02-2017, 02:22 PM | #38 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
I was under the car today and noticed the "post" O2 sensor on the passenger side is very close to the 2nd cat and located after the flange Borla uses to bolt their part# 60606 X-pipe with mid-pipe system.
If you look closely at their diagram, you can see the bung they've provided to maintain proper placement of the O2 sensor. If your shop cut the 2nd cat out there and then re-welded a straight piece in that close to the sensor (without removing it), you can bet it is toast IMHO of course. |
11-04-2017, 10:12 AM | #39 |
I agree, that is a possibility. But I now have p0420, p0430, and p2099 codes now. All mods up front will be removed and the car goes to the dealership on Monday. I will let them fiddle with it under warranty.
11-04-2017, 07:57 PM | #40 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Even with the codes cleared the engine light will come back on as long as the code is in the permanent memory of the ECM. It takes several drive cycles for the code to clear out of the permanent history and not trip the check engine light.
11-04-2017, 09:59 PM | #41 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
After my cam install, I had 3 codes kept coming back. I kept clearing them again and again. Not sure how many but it was a lot. Finally they stopped and did not come back on and car is running great.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
11-04-2017, 11:13 PM | #42 | |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
