05-24-2012, 08:17 AM | #1 |
ZL1 Differential & axles
Just wondering if the ZL1 differential and axles will bolt up to an SS camaro, found a GM website that finally carries the parts. I am going to head to my local GM dealer and ask someone there this weekend...excellent pricing on GM parts and so far they have been taking the abuse, just wondering if anyone have info
http://www.gmpartsdepartment.com/par...agramCallOut=6
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
05-24-2012, 09:24 AM | #2 |
Burning up tires
Drives: 2023 ZL1 Vert Join Date: Jul 2010
05-24-2012, 10:20 AM | #3 |
50 Shades of Prey
Drives: TT/SS Join Date: Oct 2010
So you would save a grand over the aftermarket built ones? also i believe gforce has a warranty on their's.
Futral Motorsports built and tuned
05-24-2012, 10:40 AM | #4 |
Actually if you buy the differential and both axles (manual trans) it came out to roughly $2757 before shipping, not bad for a 9.9 inch rear in my opinion, pretty good bang for the buck in my opinion
05-24-2012, 01:31 PM | #5 |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
The subframe it bolts into is different. I dont think the ZL1 diff will bolt into the SS subframe since its larger.
URR2SLO - If you're not going fast enough, get out the way......
05-24-2012, 01:35 PM | #6 |
That is the type of info I am looking for thank you
05-24-2012, 01:37 PM | #7 |
50 Shades of Prey
Yea you're right and the built ones are like $4500. I guess I just don't want to buy factory to do things they weren't designed for again. I bought an ls9r clutch and I don't make the 900 tq claim that it can handle and i feel if i bought aftermarket I could say "hey you said it's designed for this. what gives?" So I guess in short I feel like if I'm going to shell out that much money I might as well get the best I can.
05-24-2012, 02:50 PM | #8 | |
I hear you with that, after hearing about the pontential cradle difference that kinda burst my bubble...also looking on that website you can buy the ZL1 clutch and pressure plate for $332 and ZL1 flywheel for $558 which is good pricing also, just more options to look at pending peoples needs
05-24-2012, 05:45 PM | #9 |
Drives: 2009 ZR1 Join Date: May 2010
The zl1 pressure plate wont work on your stock crank. it has 8 bolts vs your ls3's 6. The actual clutch and pressure plate might though.
05-25-2012, 05:19 AM | #10 |
There is a lot of things I haven't read upon the ZL1 vs SS differences, this info is good to know!
06-27-2012, 10:56 AM | #11 |
Drives: 2010 camaro ss/rs Join Date: Dec 2009
bump!
06-27-2012, 11:17 AM | #12 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Why not just bolt a whole ZL1 cradle and rear end in?
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
06-27-2012, 11:48 AM | #13 |
number #1 reason is cost. If theres no need why spend it.
06-27-2012, 12:05 PM | #14 |
You will need new hubs too, for the axles to fit in them, and last i think the only difference in the subframe is the cooler lines and pump mounting on the subframe.
