05-01-2019, 09:56 AM | #1 |
Drives: 2017 50th Anniversary 2.0T Join Date: Jul 2018
50th Anniversary Tire Fitment aka The Dead Horse
Morning guys and gals.
I am beating the proverbial dead horse but Ive not found enough supporting info searching the forums for front fitment. So here goes. I have a 2017 50th Anniversary 2.0t. It come squared factory. I am debating staggered vs squared as I modify and track. Im pretty sure I want to stay square. Im getting the MRR M017. I was wondering if anyone knew if 305/30 will fit the front 20x10s. I know it eill the rear but again 20x10s. I plan on doing the afe loweing kit ie the 30s. Any info woud be awesome. |
05-01-2019, 10:09 AM | #2 |
Drives: 17 Z06/Z07, 17 2SS Fifty, Ram 2500 Join Date: Jan 2019
I seem to remember seeing somewhere here on the forum that it's possible but, you'll need spacers on the front. 305 is best on a 10.5" rim which you can't fit up front.
If you're planning on track use I recommend you dial back a little and save some rotating mass/weight. 285 squared would be a good setup on a 2.0t. Also even better would be to step down to 19" rims if you plan to lower the car.
Build Date 8/1/2016 1,109 out of 5,982| Club F1FTY
05-01-2019, 10:19 AM | #3 |
Yeah the offset is only 23 in the M017.
05-01-2019, 02:36 PM | #4 | |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
05-01-2019, 04:20 PM | #5 |
Here's a good thread to check out even though the car is an SS and yours is a 2.0T
19" wheels and tires on SS for Track/Street
