04-20-2019, 10:00 PM | #1 |
Drives: 2019 Camaro 2SS Join Date: Jan 2019
wheel fitment issues on my 19
So a buddy of mine has a set of vff101 20x11 with 305/35/20 Et street SS on them. they fit fine on his 2017 ss. They rub the wheel well liner horribly on my 19 and i cant figure out why. They dont rub just a little bit, they rub bad... I believe the wheels are a +44
anyone have an ideas? |
04-21-2019, 05:57 AM | #2 | |
Drives: 2018 SS Join Date: Jun 2018
04-21-2019, 01:15 PM | #3 |
SABIO
Could be the liner and/or wire routing is set up differently. ???
04-21-2019, 02:30 PM | #4 |
Drives: SS-6-SPD Join Date: Jan 2017
You need to re route the wire harness on the driver side ...
04-21-2019, 06:53 PM | #5 |
this wheel was test fit on the passenger side... there is NO WAY it would have cleared on the drivers.... even with relocating the harness
04-21-2019, 07:27 PM | #6 |
SABIO
20x11 43mm is a standard offset. A 44mm should fit with no issues.
Can you compare the inner liners of the 2 cars? share pics if you 2 are not close.
04-21-2019, 07:55 PM | #7 |
