09-11-2019, 09:07 AM | #29 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
This is what I mean. You can’t drive easy or it will not know which gear. It is fine if it is always up shifting or down shifting. Coasting confuses it. Sent from my iPhone using Tapatalk Pro
09-11-2019, 09:23 AM | #30 | |
Drives: 2019 CLA 450 Mercedes Join Date: May 2016
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
09-11-2019, 09:53 AM | #31 | |
Drives: ZL1 Join Date: Sep 2019
0
Since it was a learning day as my first time at that track next time I will prob do both for reference. For reference there was about a 40 second difference in lap time between the first half and second half due to the lead follow. I also noticed that due to the a10 shifting in the middle gears comes up quick due to the short ratios. I also thought this may have been what was happening due to him having an instructor and possibly taking it easy during those sessions, so I mentioned it. |
09-11-2019, 01:50 PM | #32 |
Drives: Gray ZL1 Join Date: Sep 2017
A10 transmissions
I had a ZL1 with an A10 transmission. It was great for 8 track days driving in D. Then the last three times I tracked the trans overhead to 300 degrees. I researched it and the bands and clutches were burnt. GM said that it should be ok and didn't need to replace the transmission. So I've since sold it and I am looking for a car that can handle extreme shifting since I drive the car very hard. Also heard of other A10 transmission having overheating problems.
I had changed the trans fluid and rear end fluid and no changes. So definitely paddle shift them on the track cause they might over heat. |
09-11-2019, 02:28 PM | #33 | |
aka BeastZL1
18 track days and no problems here. Your mileage may vary. Sent from my iPhone using Tapatalk Pro
