Old 07-20-2022, 03:59 PM   #1
Tim M
Drives: 2018 Camaro SS 1LE
Exhaust Valves? (Supercharged LT1)
Greetings!
Restarting on our LT1 build for my SS 1LE with LT4 blower.
I'm considering new exhaust valves on the OEM LT1 heads. I've already received the Ti LT4 intake valves...to reduce chances of valve float (@ ~6900 rpm).
Combination is mild 700 CHP build for extended street runs and some circuits.
Manleys? REV's? New OEM?
Thanks!
Tim M is offline   Reply With Quote
Old 07-20-2022, 04:55 PM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Tim M View Post
Greetings!
Thanks!
Inconel is best for exhaust valve use in an FI application.
Old 07-20-2022, 06:14 PM   #3
LT1ornothing
Drives: 2020 LT1 M6
I agree, have heard the same.
Old 07-21-2022, 10:30 AM   #4
ZO6Ted
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
What can be done about the seats? I understand they have a habit of falling out per TS.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror
ZO6Ted is offline   Reply With Quote
Old 07-21-2022, 11:45 AM   #5
Joshinator99
Aftermarket heads lol
Old 07-21-2022, 12:23 PM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
Well, if you really want the world's best/fastest racing valves and seats, contact my son's company here https://www.mwracing.eu/en/mw-racing/
Yes, they are expensive for most of us, but not for Ferrari et al.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 07-21-2022, 01:36 PM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Inconel. Can have the seats reworked on your stock heads.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 07-21-2022, 02:09 PM   #8
Tim M
Appreciate the comments.
Our HP goal is quite conservative and likely inconel would be wasted on our build. We would like fresh exhaust valves and curious what aftermarket offers as a suitable replacement or a step up within reasonable cost.
Possibly leaning toward OEM's or this Manley set:
https://gwatneyperformance.com/produ...1-lt4-12349-8/
Thanks.
Old 07-21-2022, 04:01 PM   #9
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I made 850 plus on my Magnuson 16 SS Camaro with stock heads, stock valves, I did have a valve job done after I broke the stock Lt1 motor, only because we did new springs and Cam. I would have liked to have had a better set of heads but didn't really think it was necessary at my power level. Back to the question, I've run Manley on many of my motors in the past, I also ran Manley Forged internals except the crank in the 1st built motor. Yes there was another. haha
Old 07-25-2022, 06:48 AM   #10
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
Ferrea super alloy exhaust valves Katech sells them
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 07-25-2022, 12:15 PM   #11
Katech_Mike
Drives: 2015 Camaro ZL1
OEM valves will do the job at that power level.
If you want to upgrade we stock Ferrea Super Alloy exhaust valves.
There is no reason to buy a heavy SS exhaust if it isn't Inconel.
Katech_Mike is offline   Reply With Quote
Old 07-25-2022, 12:32 PM   #12
laynlo15
laynlo15's Avatar
Agree with Mike, stock valves will handle a lot of power. Its the other parts of the valve train that are more important. Valve springs, proper seat pressure and a good machine shop that will take the time to set it up for you after the valve job or you engine builder.
Old 07-25-2022, 12:40 PM   #13
KingLT1
KingLT1's Avatar
I agree...I said Inconel thinking OP wanted the best after reading the first few posts. Certainly isn't needed for a mild build and there are several mid level options that will work fine along with OEM.
2016 NFG 1SS A8
Old 07-25-2022, 04:32 PM   #14
Joshinator99
OP sprung for titanium intake valves but inconel exhaust is going to break the bank?!?
