10-05-2023, 07:17 AM | #1 |
Drives: 2023 Camaro Convertible 2LT Join Date: May 2023
I4 Integrated or External Engine Oil Cooler?
I know to use the PF64 AC Delco filter now... so I changed the topic of this thread.
For the I4 engine, how do I know if I have Integrated or External Engine Oil Cooler? The difference is in the capacity of the engine oil. I either need 5 quarts (Integrated Cooler) or 5.5 quarts (External Cooler). Last edited by Shock and Steel; 10-08-2023 at 04:59 PM. |
10-06-2023, 06:24 AM | #2 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
I use super tech 5w-30 dexos1. pf 64 is same one in lt1.
B6 dampers, x pipe, mbrp axel back
10-06-2023, 05:03 PM | #3 |
Amazon Basics has a 5 quart jug with the correct specs for even less. Is there a way to see who actually produces the oil for Wal-Mart or Amazon?
The Amazon Basics jug states it's manufactured by Highline Warren Distribution in Nebraska. Apparently they make Rain-X too. The Wal-Mart (Super-Tech) jog doesn't state who the manufacturer is on the back label. Last edited by Shock and Steel; 10-06-2023 at 05:24 PM. |
10-08-2023, 04:58 PM | #4 |
For the I4 engine, how do I know if I have Integrated or External Engine Oil Cooler? The difference is in the capacity of the engine oil. I either need 5 quarts (Integrated Cooler) or 5.5 quarts (External Cooler). Any help? Last edited by Shock and Steel; 10-09-2023 at 05:28 AM. |
10-15-2023, 06:58 AM | #5 |
The dealer told me my engine oil cooler is integrated, because the external engine oil cooler part is N/A for my VIN. I guess proof by contradiction will have to suffice in this case.
10-15-2023, 12:04 PM | #6 |
External maybe for 1le.
10-16-2023, 05:38 AM | #7 |
10-19-2023, 09:58 PM | #8 |
Drives: Chevy camaro Join Date: Jul 2019
If you have the 1LE package, then you would need 5.5 qts. All others take just 5 quarts for the LTG.
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears. |
