Old 08-25-2022, 04:45 PM   #1
17camaroSS
17camaroSS's Avatar
Drives: Chevy Camaro SS
9’s N/A in the summertime
Ok, so first I want to say is the converter immediately locked, unlocked, locked back up, then short shifted into 4th on these two passes and didn’t get to make a 3rd pass with the trans tune fixed. Tuner and I believe that it would’ve ran a 9.6 that night If they wouldn’t have shut the track down a half hour early. But needless to say, I’m happy with it for only have 3 passes on the car in the summertime, trans doing what it did, and the car weighing 3,660-3,680(full factory interior, a/c, wipers, etc) depending on how much fuel is used driving to the track. Still another .1 in thw 60’ as well. But for N/A sbe that I can drive to and from the track and run 9’s is a plus in my book.
2017 1SS:Hi-Ram, FBO, OTR ram air,
Circle D converter.
Previous PB: 11.07 @124 1/4
7.1 @100 1/8 1.6 60’ w/2” longtubes,
95mm hi-ram,
OTR ramair, flex fuel
17camaroSS is offline   Reply With Quote
Old 08-25-2022, 05:13 PM   #2
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Killer passes man. Let us know what your mods are and the track. Congrats.
Old 08-25-2022, 05:40 PM   #3
17camaroSS
17camaroSS's Avatar
It’s us41 for the track and for the mods, it’s a fbo, cid heads from Cesar Tellez, Custom grind from Martin Smallwood, hi ram, pump e85, dumped x pipe with mufflers at the rearend, 6FPX converter.
Thanks man, I appreciate it! It’s definitely got more in it. I think getting the 60’ down a tenth with the new radials, it’ll run into the 9.4’s the way it sits with this new tune and updated trans tune. I’ve still got some lighter seats to out in as well once I see that slip I want to see with the factory interior in the car! Then once the weather breaks obviously, there’s some there as well.
Circle D converter.
95mm hi-ram,
Old 08-25-2022, 06:05 PM   #4
s346k
s346k's Avatar
Drives: like an old lady
id say that's a pretty good starting point. what was the cars best as bolt ons?
Old 08-26-2022, 07:54 PM   #5
Duramacr1
2Spdsy
Duramacr1's Avatar
Drives: 2021 Camaro LT1 A10
Dude that’s incredible with that heavy of a car. Congrats . Most guys going this fast are way lighter . I’m trying to be where your at with my car but I have stock ported heads, an msd intake , amd a stage 3 cam. Don’t even think I’ll get there plus I have a 3X converter so I can’t 60ft like you . But good luck and keep it up. Your proving that these cars can go 9’s SBE on full interior
Duramacr1 is offline   Reply With Quote
Old 08-26-2022, 08:04 PM   #6
17camaroSS
17camaroSS's Avatar
Best was 10.8 at 126 on a bias ply with headers, hi ram, flex fuel and homemade OTR in similar weather, and similar weight.
It’s definitely a starting point. Like I said in OP, the car would’ve seen a 9.6 with this new tune if they wouldn’t have shut the track down a half hour early lol. But when I go back, I’ll have new radials and hoping to bring that 60’ down another .1. Looking to see a 9.4-9.5 out of next outing the way it sits.
Circle D converter.
95mm hi-ram,
Old 08-26-2022, 08:07 PM   #7
17camaroSS
17camaroSS's Avatar
Thanks! It takes the right combo that’s for sure. I enjoy the fact that I can drive the car over 2 hours away to a wedding with the a/c on and sitting in the factory seats with the family in the car. All of us comfortable and enjoying it. Then drive it back from said wedding, then hop in and drive it to the track that’s an hour and half one way. That’s honestly what I enjoy most, that and knowing it’s going to go faster the way it sits while still being able to do these things.
Circle D converter.
95mm hi-ram,
Old 08-27-2022, 10:42 AM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Good runs...it's moving out!
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 08-27-2022, 11:25 AM   #9
Duramacr1
2Spdsy
Duramacr1's Avatar
The et calculator says your making about 600-615rwp with your mph at 3800lbs figuring your about 180-200lbs . So your making some impressive power with that combo . Your up there with the fast N/A guys . Pray, Midnight, etc.
Old 08-29-2022, 06:07 AM   #10
Tripwire1124
Tripwire1124's Avatar
Drives: 2022 LT1 Camaro
This is inspirational. 136 trap speed is killer as well!
Make me want to do a good heads/cam setup.
10.92 @129.3mph
Tripwire1124 is offline   Reply With Quote
Old 08-29-2022, 03:29 PM   #11
asthmamax11
asthmamax11's Avatar
Amazing times
What do you use for injectors and pumps ?
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 08-30-2022, 08:56 PM   #12
17camaroSS
17camaroSS's Avatar
Thanks man! I’m happy so far.
Circle D converter.
95mm hi-ram,
Old 08-30-2022, 08:57 PM   #13
17camaroSS
17camaroSS's Avatar
I’ve had it on the dyno and it made some decent numbers lol
Circle D converter.
95mm hi-ram,
Old 08-30-2022, 08:58 PM   #14
17camaroSS
17camaroSS's Avatar
Thanks buddy! 137 but who’s keeping track lol
Circle D converter.
95mm hi-ram,
