04-19-2022, 07:10 PM | #29 | |
'20 ZL1 1LE A10,
04-20-2022, 04:56 AM | #30 | |
Drives: 2024 Toyota Camry XSE Join Date: Sep 2017
DB, I'm not saying it is not a drag radial, it is. But, it is a drag radial SLICK, not a drag radial D.O.T. "D.O.T." being the critical, missing descriptor that would solve our problem. Hoping they will make a version of it with some groves like the Street R and get it D.O.T. approved.
2016 1SS - Bought: 8/2017 Sold: 12/2023
04-20-2022, 08:53 AM | #31 |
I ran my 275R with a 245 up front. I wonder if that is why it felt stable
04-20-2022, 10:17 AM | #32 |
Mine vibrated over the last half of the track. It has 4S 305s fronts, which I'm not crazy about for several reasons including the tread drags water out of the box. Need racing skinnies with little tread.
'20 ZL1 1LE A10,
04-20-2022, 08:29 PM | #33 |
I back into the box. Yeah skinnies will do the trick and make you faster. I am 60min from the track and no car trailer, otherwise I’d have skinnies…I’d prob have bias plys too tho
One can dream
04-20-2022, 08:36 PM | #34 |
I don't believe the track will let me back in, but I'll ask. If I stay with 19" fronts, I could do a Nitto 245/30R19
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 04-21-2022 at 08:39 AM. |
04-21-2022, 12:59 AM | #35 |
Drives: like an old lady Join Date: Jun 2012
don't let that slow you down. i'm 90+ miles from one here. i drove up there and back on the 18x5s. id have done 17s if i didn't drive it so much on the street.
04-25-2022, 08:21 PM | #36 |
Bandimere will not you drive around and back into the box, because Roy Hill got run over by a racer who did that at some NHRA track.
'20 ZL1 1LE A10,
04-25-2022, 09:00 PM | #37 |
Drives: 21 ZL1 Join Date: Feb 2022
I took the gamble on another set of MT ET street SS's. 305/45/17. Both balanced with minimal weight and work well on the street with no vibration. Im happy with them. My last same size set were a mess. Never would balance correctly.
04-26-2022, 08:10 AM | #38 | |
I then put the Toyo R888Rs on with 32# and they also shook down track. After the 2nd pass, the car went completely dead, so much so that even the manual trunk release wouldn't work. A 100% dead Antigravity battery. I then put the OEM battery back in it, increased rear pressure to 36 and front to 38. No shake or elec. issues. My guess is that I would NOT feel any shake with the MT with higher pressures, say, 20-24, and a good battery, i.e., no elec. issues. Having said all that, I'm putting NT05 on it this week, 245 front, 335 rear.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 04-26-2022 at 08:24 AM. |
