02-14-2022, 07:26 AM | #1 |
Drives: 2020 Cadillac CT5 Sport Join Date: May 2021
How should I secure my Subwoofer box?
I am installing my subwoofer box in my 2018 2SS w/ Bose. Well versed with connections and how to tap into all necessary wiring. Simply looking for advice on how to secure the box with a couple goals in mind.
Goal is to have it secure AND easily taken out AND not add additional weight other than the sub and amp. Subwoofer Box Dimensions are 26" x 13" x 12" (Toby Speakers Fort Worth, circa 1995) I'll mount the Alpine & LOC amp within factory foam underneath.
2020 Cadillac CT5 Sport Summit White / Jet Black
2018 Camaro 2SS Hyper Blue 2014 Chevy SS White 2014 Silverado High Country 2008 Pontiac G8 GT - White Axel Back Solo / Volant CAI |
02-14-2022, 09:48 AM | #2 |
How secure do you need it?
Buy some strips of Velcro at walmart. This is in the fabric/crafts area and they have a good assortment. Just put the hook-sided stuff on the bottom of your box. That should grab the carpet enough to prevent sliding. |
02-16-2022, 06:54 PM | #3 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Yes I have used industrial velcro to hold my custom built wood box with two 10s successfully for 5 years.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
02-17-2022, 09:01 AM | #4 |
Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
02-17-2022, 09:01 AM | #5 |
My only concern with this is the back of the factory "floor" is not reinforced with anything. It's just carpet/padding.
I'll have to test it out to see how well it stays in place.
02-17-2022, 07:25 PM | #6 |
Drives: 18 camaro 1ss 1le Join Date: May 2021
take out the carpet, trace it to a piece of MDF and cut it. cut it in the middle to the same dimensions of the small board already attached to the carpet, and you have a new floor to mount things to. Add your own carpet or peel off the original carpet and use Super 70 to glue it to the new pieces.
05-23-2022, 03:07 PM | #7 |
Drives: chevrolet camaro Join Date: Jul 2020
go for a ratchet tie down strap, all you need is two secure points and you are all good. i have the same box that i have moved thru a handful of cars and love it
