02-17-2022, 02:59 PM | #15 |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
How does it sound? Might have to consider one of these for my vert.
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
02-18-2022, 08:27 AM | #16 | |
Drives: 2020 Callaway Camaro SC630 Join Date: Feb 2020
I then put one in my 2021 double cab Silverado laying on the middle of the floor under the rear seat. That one had the factory amp already and this made it sound like a bigger system with some good thumping on top of it. The difference was dramatic (more) in the Camaro (1SS system), but I cannot say enough about them in either situation. If you have an amped system already, do not let someone tell you that you need the 100 dollar device (forgot the name) to allow for this to work. This unit has the right adjustment options built into it.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue |
02-19-2022, 07:36 AM | #17 |
I'm just about to order this enclosure for my 2 Kicker S12d old school subs. Based on the pics on the site, I can't tell where the terminals are installed or if the front (where the subs are mounted) is angled or straight.
Do you have pics of the box before install or just the info would be great as well. TIA
2021 2SS A10 - Summit White - NPP - MRC - Adrenaline Red Interior Pkg - Black Appearance Pkg - Ground Effect Pkg - Suede Steering Wheel and shifter - Red Calipers - Carbon Flash Wheels w black lug nuts - DD Tinted Side Markers - Hero Tinted Rear Reflectors - Redline Fender Badges - 20% Tint
Audio System Build Log ----------------------------------------------------------- 2014 Z/28 Summit White - sold 2020 2010 2SS/RS Summit White - sold 2014 |
02-19-2022, 07:40 AM | #18 |
Drives: 18 zl1 garnet red Join Date: Aug 2021
Loving all these setups, thanks for posting. Giving some great ideas
02-20-2022, 08:21 PM | #19 | |
Drives: 18 camaro 1ss 1le Join Date: May 2021
There is one terminal for each sub on the side ends, i went with the gold terminals option. its a round 4"ish diameter plastic housing with two screw terminals like on a home theater setup. kind of like this https://www.amazon.com/Absolute-SST-.../dp/B00N32HQEU |
03-21-2022, 02:08 AM | #20 |
Drives: 2021 3LT RS A10 Join Date: Nov 2021
I was into big building systems in the 90s, but what's the recommended setup for a '21 3LT with the Bose factory system? I'm just looking to add an amp & sub(s).
How big of an amp can I put in without impacting the stock electrical system? Recommended wattage & speaker size to pair with the existing audio system? Thanks |
03-21-2022, 05:23 AM | #21 |
Drives: 2022 camaro 2ss 1LE Join Date: Dec 2021
03-24-2022, 09:43 AM | #22 |
Thank ya
04-29-2022, 03:32 AM | #23 | |
Drives: 2011 SS A6/ 1994 Pontiac T/A M6 Join Date: Jun 2017
Adding amp and subs
04-29-2022, 09:08 PM | #24 |
Drives: 2022 Camaro 2SS 1LE Join Date: Nov 2021
My install was simple and took me about an hour to get it in. Doesn't take much adjusted all the bass out of the factory setup and only dropping through the subs. Sounds nice and clean.
04-30-2022, 02:09 AM | #25 |
Nope I haven't gotten around to it yet either.
05-02-2022, 08:43 AM | #26 |
Drives: Chevy Camaro Join Date: Apr 2020
A decent line out will have a remote turn on for the amp. The lc2i is pretty bottom of the barrel and will get the job done cheaply
05-02-2022, 10:29 PM | #27 |
Drives: '22 Camaro ZL1 1LE A10 Join Date: Jul 2021
Nothing too fancy for my setup. Just needed some thump. 12in Kicker with a Kenwood amp.
Using velcro to keep the sub in place in the trunk and the amp in place on the sub. Kicker 12in 2ohm downward firing sub. https://www.crutchfield.com/p_20648C...8CVTDF122.html Kenwood Excelon X502-1 500w RMS 2 ohm https://www.crutchfield.com/p_113X50...on-X502-1.html |
05-03-2022, 11:56 AM | #28 |
Petro-sexual
Do any of you think you need to add a secondary (or upgraded OEM) battery, or any other electrical upgrades to run around a 1200w RMS sub amp? I have one that I've been kicking around adding to the trunk, but don't know if I want to, because of the additional electrical load.
I can't figure out how to get the enclosure in the trunk, either, lol... I have a 12" sub cube I could throw in there if I want, too.
