Roto-Fab
Old 06-03-2018, 02:11 PM   #1
MrTwenty6
MrTwenty6's Avatar
Drives: 2014 Camaro SS 1LE
LT header install help
I'm finishing up my long tubes installation and have issues with reinstalling spark plugs.
The plug wires are touching the header pipes, is this normal?
MrTwenty6 is offline   Reply With Quote
Old 06-03-2018, 02:40 PM   #2
frack
Drives: 2010 Inferno Orange SS
Yes, its usually always that same one that touches. No big deal. I actually shaved a bit of the the boot on mine off, but that was after 2 years of touching the header with no issues.
frack is offline   Reply With Quote
Old 06-03-2018, 02:47 PM   #3
MrTwenty6
MrTwenty6's Avatar
The plugs for the next one seem to be touching as well.
I didn't look when I pulled them initially but does it look like they are not all the way in? I have tried to push them in snug but maybe they need to go in more?
Old 06-03-2018, 02:50 PM   #4
samgray20
samgray20's Avatar
Drives: 2010 CGM 2SS/RS M6
If I remember correctly, when I had 1-7/8" Kooks, the stock wires did not touch the primaries. I have 2" Kooks now with aftermarket wires and boots and would not risk it with the stock wires. Those stock wires are not easy getting on and off the plugs either, so make sure that they are actually all the way on.
2010 CGM 2SS/RS M6 - Comp 227/243 .620/.612 | Nitrous Outlet Plate Kit - 100 Shot | ARC Bottle Bracket/Heater | NOS Progressive Controller | AEM Wideband | Kooks 2"x3" LTs | 3" Custom Catback | CAI Intake | Bo White PTB | Billet Motor Mounts | Hurst Short Throw | McLeod RXT | RAM TOB | 3.91 W/ Eaton Truetrac, LPW Cover, Poly Bushings, GForce 850HP Axles | Eibach Pro-Plus Kit | Whiteline End Links | Hotchkis Tower Brace | ZL1 Front End | Blue Powder Coated Calipers | Vorsteiner V-FF 101 - 20x11 and 20x10 | M/T Street Comp - 305/35 and 275/40 | 2 JL Amps | Diamond Audio Speakers | JL Stealthbox
samgray20 is offline   Reply With Quote
Old 06-03-2018, 06:26 PM   #5
Gordy87
Gordy87's Avatar
Drives: 2010 Camaro SS
Could always go with some aftermarket wires. My factory wires were to close for my comfort when I installed my LTH's, so I purchased some Granatelli wires, and there clearance is a lot better.
Gordy87 is offline   Reply With Quote
Old 06-03-2018, 09:01 PM   #6
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Those wires don't look like they're fully seated. Did you hear/feel them click on to the plugs?
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 06-04-2018, 07:06 AM   #7
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
What brand of headers are those? None of mine were touching, although a couple were fairly close. Maybe within a 1/4".
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 06-04-2018, 07:12 AM   #8
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
None of my wires touch my headers...
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 06-04-2018, 10:27 AM   #9
BLU DUCE
BLU DUCE's Avatar
Drives: 2011 1SS/RS IBM Camaro
I have Kooks 1 7/8 and my OEM wires do not touch the headers. All the plug wires are the same size and it doesn't matter which one goes on which plug. You just have to make sure they are angled & spaced on there just so. And when you are pushing them on you can hear them snap on and set correctly.
BLU DUCE is offline   Reply With Quote
Old 06-04-2018, 01:00 PM   #10
MrTwenty6
MrTwenty6's Avatar
These are speed engineering headers. More pics attached. Nevermind the dipstick - that's been a nightmare
I will get some plug wrenches and see if that helps. Anyone have pictures of theirs for reference?
Old 06-04-2018, 01:04 PM   #11
metrogdor22
Drives: 2013 2SS M6
Mine (TSP 1-7/8") don't touch and I've never heard anybody say that's okay. Plug wires do melt. If the rubber boots are pushed all the way in until they click, I'd contact the manufacturer and ask them about it.
2013 2SS M6 - Custom cam w/ miscellaneous valvetrain upgrades, ported heads, longtubes, CAI, CTS-VR lifters, Forza NPP exhaust controller - 500hp/460tq
metrogdor22 is offline   Reply With Quote
Old 06-05-2018, 08:57 AM   #12
MrTwenty6
MrTwenty6's Avatar
Got my plugs in more tightly, they seem to be clearing the header pipes now.
That being said, I think i'll swap them for some aftermarket ones. Any suggestions?
Old 06-05-2018, 09:21 AM   #13
samgray20
samgray20's Avatar
My car has Taylor wires. MSD and Granatelli are some good name brands also.
Sent from my SM-N950U using Tapatalk
Old 06-05-2018, 09:47 AM   #14
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Use Taylor wires and a heat boot, they shouldn't be touching the header
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
