09-09-2017, 05:35 PM | #1 |
Drives: 16’ 2SS A8 HBM Procharged Join Date: Jun 2017
Need suggestions for rear drag wheels / tires
Hi all. As the title states I'm looking for some opinions on a budget friendly rear drag setup. You can see my mods in my signature. I want something that won't be too far off of the height of my front wheels (285/30/20). I'm not sure if a DR or slicks is the way to go. I want traction at the strip, my 305/30/20 Michelin PS4s are not going to bite, at least not in first gear. Also don't want to be snapping my stock axles either.
I saw another thread with drag star bracket racers which seem like a reasonable cost, but I still don't know where to go with the tire size and if a DR is ok or if I will need slicks. Any suggestions would be greatly appreciated. -Phil
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
09-12-2017, 01:06 AM | #2 |
Drives: 2016 1ss m6 Camaro Join Date: Jul 2016
budget friendly? 17inch racestars with a 28x10 bias ply slick,i run the hoosiers,your a m6 car you dont want a drag radial unless you wanna break stuff.
2016 camaro 1ss,m6-npp,tsp longtubes,no cats,e85,tuned by rpm motorsports(451hp/467tq),
17"race stars drag pack,bmr upper and lower trailing arms,bmr upper control arms,bmr front cradle brace,gforce outlaw axles/driveshaft,lnf 2step. Best 1/4 mile of 11.2@122mph |
09-12-2017, 02:38 PM | #3 |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
Sorry for the ignorant question but what is the major difference between the drag radial and a slick? Just sticker?
09-12-2017, 02:43 PM | #4 |
I'm curious. What would break if using a DR and not break if using a Slick?
09-12-2017, 02:54 PM | #5 |
Anyone have a link to the correct offset and whatnot for those drag stars? I want to finally order them and seem to have a hard time figuring out which the right ones are
09-12-2017, 03:24 PM | #6 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
I believe you'll get more sidewall flex and better launches with slicks and that seems to work better with M6 cars. If A8, go with DR.
09-12-2017, 03:26 PM | #7 | |
https://www.summitracing.com/parts/r...8aAoHMEALw_wcB
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. Last edited by grampa_ss; 09-12-2017 at 04:09 PM. |
09-12-2017, 03:35 PM | #8 |
Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
09-12-2017, 07:59 PM | #9 | |
09-12-2017, 11:17 PM | #10 |
17x9.5 race stars and 28x10 hoosiers as slow has said. I have a A8 with this setup and have over 100 runs on the Hoosiers. Slicks do not shock the drive train as a drag radial will and you'll end up with broken drivetrain parts. I've been there with a M6 corvette, the softer sidewall on a slick allows softer launches when you dead hook.
09-13-2017, 04:14 AM | #11 |
Using bias-ply tires on the back with radials on the front is probably not a recommended combination due to handling problems. Since you want to use your 285 radials on the front, something to think about.
09-13-2017, 06:16 PM | #12 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
Everyone says that the slicks are better for an M6.....my car didn't agree. 2900 miles, Hoosier 28x10 slicks, and a good launch.....I ended up trailering my car to the dealer for an axle.....
It was 100% stock until it came back from the dealer. My next set of tires are going to be 305/45r17's and radials up front on skinnies. If radials hit harder then my axle snapping slicks, I can't wait to test the GForce lifetime warranty!
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
09-13-2017, 06:18 PM | #13 |
Not as big of an issue as one would think.....I do it. Stockers up front and Hoosiers out back. It dances a bit. The old adage of not mixing bias ply and radial was meant for the same axle. Don't put a radiator on the right side and a bias ply on the left. That will kill a diff, and potentially cause stability issues.
09-13-2017, 06:59 PM | #14 |
Thank you guys for the information. But based on the feedback I am more torn now than I was before haha. Here is what I am about to order, after I decide between the two tires.
Race star 17x9.5 (does a 6 offset work or does it need to be the 6.43 or whatever? I can get the 6 offset cheaper and sooner than the other). Hoosier slick 28x10 OR 305/45/17 MT ET street R.
