dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 09-11-2017, 05:51 AM   #29
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Yes....the price of eggs isn't worth the wear and tear on a chickens butt.. J/k. Never a problem with the locks
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 10-28-2017, 03:13 PM   #30
dysart316
Drives: 2011 2ss/rs, 1969 camaro
My 2011 just started doing the same thing. It has been consistent over the last month. Has never did they 1 time in the prev 6 years.
dysart316 is offline   Reply With Quote
Old 12-11-2017, 12:29 PM   #31
kbayliss
Drives: 2011 2SS RS Victory Red Coupe
Mine started about a month ago. Thought I was out of my mind. Have had the car for 5 years. No problems until now. 2011 2SS RS
Anyone come up with an idea?
kbayliss is offline   Reply With Quote
Old 12-12-2017, 10:49 AM   #32
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Did you recently replace the car battery and lose the door lock settings you had previously on the car during a battery replacement?
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 12-13-2017, 06:51 AM   #33
kbayliss
Nope. No changes to the car recently. Knock on wood, it's been very reliable. Just this weird door lock thing. As a matter of fact, it did it again last night. I did double check the door lock settings and they are all "off".
Old 12-13-2017, 07:02 AM   #34
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Family member using the ONSTAR Phone App and the lock car feature to lock it up at night or play joke on you? ;-)
... If not maybe the Body Control Module (BCM) is acting up -or- disconnecting the car battery for a while may reset back to normal behavior?
An experiment to try with a window DOWN is to leave ALL KEY FOBS in the car - that is suppose to override and prevent the car from trying to do any Passive Lock on the doors.
Old 12-13-2017, 10:34 AM   #35
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Originally Posted by TAG UR IT View Post
I leave a window rolled down now which stinks since it's kind of cold out....lol...28 or so degrees. SO...when I get in the car, it's colder than normal. But, yeah...I have the car off, leave the key in the center console (again, garage is locked...and if someone wants to steal the car, it's not like they couldn't get the keys in the house where they normally hang), and with the car off, it'll lock out of the blue. I am pretty sure no one is hitting the door lock down with the window down...since it's happened with the windows in the up position.
What do you have the Auto Door Unlock set to ?
This allows selection of which of the doors will automatically unlock when the vehicle is shifted into P (Park) (automatic transmission) or when the key is removed from the ignition (manual transmission). Press the MENU/SELECT knob when Auto Door Unlock is highlighted. Turn the knob to select All Doors, Driver Door, or Off.
camguynj is offline   Reply With Quote
Old 01-04-2018, 07:45 AM   #36
kbayliss
Still no luck
I did the battery disconnect last weekend. Thought maybe it worked. But this morning, the same thing-locked on it's own. Quite an odd anomaly.
Old 01-04-2018, 06:46 PM   #37
fly2hip8
Drives: 2013 Camaro 2SS
Don't leave keys in car...problem solved. If your car gets stolen and you leave your keys in the car that is on you. Make somebody work for it if they really want to steal your car.
fly2hip8 is offline   Reply With Quote
Old 01-04-2018, 06:58 PM   #38
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
Originally Posted by Angrybird 12 View Post
I just read my owners manual and there is no option to prevent that, just to delay locking. If you have a manual transmission and leave the key in the ignition it will lock after you close the door. Only solution is remove the key from the ignition and drop it in the cup holder.
I have not checked the manual. But, my 2012 will not auto lock unless it is switched on or running. Never just sitting there
PeteD is offline   Reply With Quote
Old 01-04-2018, 07:00 PM   #39
PeteD
PeteD's Avatar
OK so I guess I will ask the question. Does it do it if say,,,, you take the key inside for the night?
Old 01-05-2018, 06:57 AM   #40
kbayliss
After I realized I wasn't the one accidentally locking the car in my garage, I do take the key out. While that does solve a problem, it does not solve THE problem. I can deal with not leaving a key in it. I only worry what uncommanded thing it starts doing next.
Old 01-08-2018, 06:52 PM   #41
PeteD
PeteD's Avatar
LOL....Radio will probably work intermittently
Old 01-21-2018, 06:04 PM   #42
Cranial Disruptor
Drives: 2011 Camaro 1SS
My 2011 started doing this a few months ago. I haven't changed any door lock settings.
Cranial Disruptor is offline   Reply With Quote
