TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 08-22-2010, 02:53 PM   #1
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Post
A large group of us went to a driving school this past weekend to "learn high performance driving skills."
During my 4th and final 20 - 24 min course run, my brakes hit the floor at about 80mph. Needless to say, I mumbled, "awe shit..." as we approached the corner. I pumped the brakes a few times and went into the corner with too much speed throwing me at the very edge of the track. Luckily, it was a corner that I could go into a bit faster...and not a corner that had a barrier, creek, trees, etc. It could have been bad.
So, with that happening and losing my brakes (so not cool), I figured my brake fluid began to boil. If that happens, condensation and air begin to build up in the lines. From here on out, I learned that my brake fluid will boil more quickly and my brakes won't work to the best of their "Brembo" ability. I can't ever let this happen again on ANY track or ANY street.
So, I bought Super Blue Racing DOT 4 brake fluid. Yes, the cap on the cylinder says DOT 3. This confused me and I wanted to make sure I was not about to screw something up. So, I began reading and reading.
In my search, I found this to be EXTREMELY helpful. I wanted to make SURE that everyone here go the same info I just had and was able to make a well informed decision on their own if they ever decide to head out to a "driving school," 1/4 mile track, road course, or plain flat out, RACE.
Check out the link here. It could SERIOUSLY help.
Understanding Brake Fluid
Automotive brake fluid has many responsibilities. Corrosion protection and lubrication of brake system components are only a portion of the role brake fluid must play.
All automobiles that have a hydraulic braking system must use brake fluid in order for the brake system to operate. The type of fluid used can depend on the type of vehicle and the demands of the vehicles brake system.
The two most common brake fluids used in the automotive industry are fluids that contain Polyalkylene Glycol Ether and fluid that contains Silicone or Silicium-based Polymer. Both Fluids are common but very different in regards to the manner in which they perform. Fluids containing Polyalklene Glycol Ether are more widely used and are the only fluids that should be used in racing brake systems.
Because brake systems may reach extreme temperatures brake fluid must have the ability to withstand these temperatures and not degrade rapidly.
SILICONE BASED FLUID
Fluids containing Silicone are generally used in military type vehicles and because Silicone based fluids will not damage painted surfaces they are also somewhat common in show cars.
Silicone-based fluids are regarded as DOT 5 fluids. They are highly compressible and can give the driver a feeling of a spongy pedal. The higher the brake system temperature the more the compressibility of the fluid and this increases the feeling of a spongy pedal.
Silicone based fluids are non-hydroscopic meaning that they will not absorb or mix with water. When water is present in the brake system it will create a water/fluid/water/fluid situation. Because water boils at approximately 212º F, the ability of the brake system to operate correctly decreases, and the steam created from boiling water adds air to the system. It is important to remember that water may be present in any brake system. Therefore silicone brake fluid lacks the ability to deal with moisture and will dramatically decrease a brake systems performance.
POLYGLYCOL ETHER BASED FLUIDS
Fluids containing Poly glycol ethers are regarded as DOT 3, 4, and DOT 5.1. These type fluids are hydroscopic meaning they have an ability to mix with water and still perform adequately. However, water will drastically reduce the boiling point of fluid. In a passenger car this is not an issue. In a racecar it is a major issue because as the boiling point decreases the performance ability of the fluid also decreases.
Poly glycol type fluids are 2 times less compressible than silicone type fluids, even when heated. Less compressibility of brake fluid will increase pedal feel. Changing fluid on a regular basis will greatly increase the performance of the brake system.
FLUID SPECIFICATIONS
All brake fluids must meet federal standard #116. Under this standard is three Department of Transportation (DOT) minimal specifications for brake fluid. They are DOT 3, DOT 4, and DOT 5.1 (for fluids based with Polyalkylene Glycol Ether) and DOT 5 (for Silicone based fluids).
MINIMAL boiling points for these specifications are as follows:
Dry Boiling Point Wet Boiling Point
DOT 3 401ºF 284º F
DOT 4 446º F 311º F
DOT 5 500º F 356º F
DOT 5.1 518º F 375º F
Racing brake fluids always exceeds the DOT specifications for dry boiling points. Wet boiling points generally remain the same.
DOT 3 VS. DOT 4 and 5.1
AFCO's 570º brake fluid is a DOT 3 type fluid. However, it has a dry boiling point that is 52º higher than DOT 5.1 specifications, 124º higher than DOT 4 specifications and 169º higher than DOT 3 specifications. AFCO's 570º fluid meets or exceeds all DOT 3, 4, and 5.1 lubrication, corrosion protection and viscosity specifications.
AFCO's 570º racing fluid meets but does not exceed federal standards for wet boiling point specification; therefore, its classification is DOT 3. Because AFCO's 570º fluid is intended for use in racing type brake systems that undergo frequent fluid changes, exceeding federal standards for wet boiling points is of little concern. Racing brake fluids always exceeds the DOT specifications for dry boiling points. Wet boiling points generally remain the same.
WET VS. DRY BOILING POINT
The term boiling point when used regarding brake fluid means the temperatures that brake fluid will begin to boil.
WET BOILING POINT
The minimum temperatures that brake fluids will begin to boil when the brake system contains 3% water by volume of the system.
DRY BOILING POINT
The temperatures that brake fluid will boil with no water present in the system.
MOISTURE IN THE BRAKE SYSTEM
Water/moisture can be found in nearly all brake systems. Moisture enters the brake system in several ways. One of the more common ways is from using old or pre-opened fluid. Keep in mind, that brake fluid draws in moisture from the surrounding air. Tightly sealing brake fluid bottles and not storing them for long periods of time will help keep moisture out. When changing or bleeding brake fluid always replace master cylinder caps as soon as possible to prevent moisture from entering into the master cylinder. Condensation, (small moisture droplets) can form in lines and calipers. As caliper and line temperatures heat up and then cool repeatedly, condensation occurs, leaving behind an increase in moisture/water. Over time the moisture becomes trapped in the internal sections of calipers, lines, master cylinders, etc. When this water reaches 212º F the water turns to steam. Many times air in the brake system is a result of water that has turned to steam. The build up of steam will create air pressure in the system, sometimes to the point that enough pressure is created to push caliper pistons into the brake pad. This will create brake drag as the rotor and pads make contact and can also create more heat in the system. Diffusion is another way in that water/moisture may enter the system.
Diffusion occurs when over time moisture enters through rubber brake hoses. The use of hoses made from EPDM materials (Ethlene-Propylene-Diene-Materials) will reduce the amount of diffusion OR use steel braided brake hose with a non-rubber sleeve (usually Teflon) to greatly reduce the diffusion process.
THINGS TO REMEMBER
Brake fluids dry boiling point is more important then wet boiling point when used in a racing brake system.
Passenger cars very rarely will undergo a brake fluid change making the wet boiling point more important.
Racing brake system fluid is changed often and a system with fresh fluid will most likely not contain water.
Because of this, racers should be concerned with the dry boiling point.
Racing fluid exceeds DOT 3, 4, and 5.1 dry boiling point specifications.
Never use silicone based fluids in racing brake systems.
Using racing brake fluid will increase performance of the braking system.
Never reuse fluid. º Never mix types or brands of brake fluid.
Use smaller fluid containers that can be used quicker.
If fluid remains in container be sure to tightly seal and do not store for long periods of time.
Purge system (complete drain) and replace fluid often.
Immediately replace master cylinder reservoir cap following any maintenance.
$129.00
Not bad.
Here's some more info for those wanting to know how to bleed those brakes.
#1 Remove the top of the master cylinder reservoir.
#2 Using a turkey baster, suck out as much of the old dark inky fluid as you can.
#3 Clean any sediment out of the reservoir with a clean, lint-free rag. (Do not spill any brake fluid on any painted surfaces, it will remove the paint immediately.)
#4 Fill the master cylinder with clean brake fluid.
#5 Replace the top of the master cylinder reservoir.
#6 Pump the brake pedal several times (15 or more).
#7 Using a box wrench that fits the bleeder bolt, loosen the bleeder valves, but leave them closed. (A little penetrating oil drizzled on the bolts the day before will help to loosen them).
#8 Using a piece of clear plastic tubing (aquarium tubing works fine), push one end of the tube over the brake bleeder bolt.
#9 Put the other end of the tube into a small, clear bottle with an inch or two of clean brake fluid in it. (This will keep air from being sucked back into the brake cylinder.)
#10 Put a piece of 1 x 4 lumber or some other "spacer" under the brake pedal to prevent the pedal from traveling too close to the floor.
#11 Remove the top of the master cylinder reservoir.
#12 Top off the master cylinder reservoir with fresh fluid.
#13 Replace the top of the master cylinder reservoir.
#14 Have your helper sit in the driver's seat and slowly depresses the brake pedal with an even force and hold it down. The helper should shout "down" when the pedal is down as far as it will go.
#15 Starting with the rear passenger wheel (back right for righthand drive cars), turn the bleeder bolt to the left one quarter-turn. Old fluid and air will go down the tubing into the bottle. When the fluid stops, close the bleeder valve.
#16 Shout "up" to your helper, who at this point should remove his foot from the pedal allowing it to move up.
#17 Repeat this process until new, clear fluid comes from the bleeder tube. (After every five (5) times the brake pedal is depressed, top off the master cylinder reservoir with fresh fluid. Never let the reservoir get too low, or air will be sucked into the master cylinder.)
#18 Tighten the bleeder bolt.
#19 Repeat steps 14 to 17 on the left rear wheel.
#20 Repeat steps 14 to 17 on the right front wheel.
#21 Repeat steps 14 to 17 on the left front wheel.
TAG UR IT is offline   Reply With Quote
Old 08-22-2010, 02:59 PM   #2
Atti2de
Móderator
Atti2de's Avatar
Drives: 2SS/RS
Wow, great info so glad u shared this with us...
I'm not the one with the Atti2de problem it's everyone else that has a problem with my Atti2de!
Atti2de is offline   Reply With Quote
Old 08-22-2010, 03:03 PM   #3
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
TAG -
Thanks for posting such a great article. Again, it's the little things that really add up to make a safe vehicle, especially in racing conditions. I use Wilwood EXP 600 fluid in my "HP" vehicles for that very reason. No one thinks of brake fluid, just brakes, but you found out first hand - it makes a BIG difference.
Thanks again for the Thread. Should help some others stay out of trouble.
speedster is offline   Reply With Quote
Old 08-22-2010, 03:13 PM   #4
TAG UR IT
TAG UR IT's Avatar
Happy to help.
Now....I'm thinking of upgrading to stainless steel brake lines. (Honestly, losing my brakes like that kinda got me prettttttty damn nervous. I am NOT going to let that happen again!)
Old 08-22-2010, 03:39 PM   #5
speedster
SST...
speedster's Avatar
Originally Posted by TAG UR IT View Post
Happy to help.
Absolutely upgrade to BSS brake lines. MTI on this site has a good set. Goodridge makes them, StopTech makes them. Hate to sound like a broken record, but all our HP vehicles have been equipped with BSS brake lines.
Old 08-22-2010, 11:04 PM   #6
TAG UR IT
TAG UR IT's Avatar
Doesn't sound like a broken record to me! This is EXACTLY the kind of information that I'm looking for. What type of stainless steel brake lines?..."BSS, carried by MTI." THIS helps!
THANK YOU!
Old 08-23-2010, 02:55 AM   #7
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
In addition to allowing some heat dissipation through the BSS lines, they also give a better, more solid feel to braking since they don't expand like rubber lines do thus you won't feel your brakes getting spongy as they heat up.
If you want a nice upgrade, especially you guys who've boosted your power, try the Racing Brake 2-piece drilled/slotted rotors. Besides being 6 lbs lighter than the stock rotors, they do a great job of ventilating and dissipating heat. And they look seriously cool too.
Here's how they look on my car (these are the fronts):
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 08-23-2010, 12:35 PM   #8
TAG UR IT
TAG UR IT's Avatar
I remember you getting those....talking about unsprung weight, etc. How are they treating you?
Old 08-24-2010, 10:24 PM   #9
KEEP RT
Wonderfully Awful Idea
KEEP RT's Avatar
Drives: 2010 2SS/RS
Excellent info. I am wondering though it often says NOT to mix types of fluid. How do you ensure that you are getting all the DOT3 out? There is always a bit left coating in the lines, master and calipers. (may not seem like it but 1oz. or a shot glass full is a very large percentage) Are you running enough thru to "flush" out the old? I upgraded my 57Caddy to front disc, I replaced it with all new. now it stops on a dime. After all if you cant stop don't start. It's just a question, I'm not questioning your intelligence.
KEEP RT is offline   Reply With Quote
Old 08-25-2010, 12:05 AM   #10
TAG UR IT
TAG UR IT's Avatar
the old stuff is a black/gray/clear fluid. The fluid that I used is blue (super blue racing DOT 4). You remove (with a turkey baster, etc) from the master cylinder and then pour in the new beginning to bleed one line at a time until you get blue fluid that comes out. Sure, there's going to be a teeny tiny bit left over... But, the majority will be out.
If you want to, you can always take the car to a professional shop. They have machines to properly drain the fluid out of the cylinder.
Old 08-25-2010, 02:15 AM   #11
Doc
Doc's Avatar
The rotors and braided stainless steel lines are great. Braking is very solid and linear; no sudden grabbing. Soon as they get the rear rotors done I'll be adding those and enjoying the performance.
1SS/RS LS3 M6 IBM
Old 08-25-2010, 04:21 AM   #12
michael's maro
RAM'S CAMARO
michael's maro's Avatar
Drives: 2010 camaro ss 2015 Z-28
Great write up...Lots of great info
michael's maro is offline   Reply With Quote
Old 08-25-2010, 08:40 AM   #13
TAG UR IT
TAG UR IT's Avatar
I figured after my little incident, it might be helpful to others...and if could save one person from flying off the track (better understanding what could happen IF they stayed with DOT3 OR got on the brakes that hard that often), then it's definitely worth the time to write up. I hope some folks put this to good use!
I have DOT4 in my lines now and if someone makes me a good offer on some new stainless steel brake lines, I'll pick some up.
Old 08-25-2010, 10:19 AM   #14
Doc
Doc's Avatar
The main problem with the factory brake fluid is it's not rated for track use. The repeated hard use on the track causes the factory fluid to boil and then you have no brakes. Super Blue or something equivalent is in fact rated for racing with a much higher boiling point so anyone tracking their car should definitely make this change.
The braided lines aren't that expensive; I got mine from Racing Brake but I know Pedder's and other sells them and the price is around $120 I believe give or take a few bucks. It's an upgrade that is WELL worth it.
1SS/RS LS3 M6 IBM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 09:17 PM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 12:08 PM
