09-05-2019, 07:59 PM | #1 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Cam with stock exhaust
I want to do a cam but leave the stock exhaust in place. I love the sound the way it is with the Solo Performance axleback and stock cats! If I do a cam will it be ok with stock cats? I just don’t want to do headers because it’ll be too loud. I know I’ll be sacrificing a bit of power due to the restrictions of the cats but I’m really wanting that badass lumpy idle with a decent bump in power. I don’t race so it would be a street friendly cam. Your thoughts are appreciated!
09-06-2019, 01:52 AM | #2 |
Drives: SS 6 speed of course Join Date: Jan 2016
I’d go with a cam similar to the LS7 spec. It was made to work with a similar header and factory cats and last a reasonable time. 211 / 230. 12X LSA.
https://www.hotrod.com/articles/ls-cam-test-comparison/ I know these are not LT1s. Comp has a 216 / 228 AFM.. Both cams idle...you would have to custom spec a 216 / 228 112 LSA or even bigger for an aggressive idle. 228 / 240 on 112 would be about the limit. This is close to the hot cam, also made for stock header. Hot is 228 / 248 on 112
09-06-2019, 02:15 AM | #3 |
Oh and I don’t think the bigger ones will work well on auto with stock converter
09-06-2019, 05:18 AM | #4 |
BL1ZZRD
Mines a manual so no worries about TC
09-06-2019, 08:46 AM | #5 |
Yes you can install a cam with stock exhaust...Kip from cam motion put a low lash solid roller in his C6 Vette with stock exhaust. The 6th gen SS has much better flowing Tri-Y's then the C6 manifolds. Call Cam Motion and tell them what you are looking to do.
2016 NFG 1SS A8
09-06-2019, 02:45 PM | #6 |
The smaller cam motion cams are around .600 lift. I'm lift phobic now especially for a car where ultimate power is NOT the goal. I'd dive up 20 to 30 HP for a cam that can go 100K.
09-06-2019, 03:10 PM | #7 |
Grind Number: XA218/330-XA228/325-14+5
Hydraulic Roller Camshaft Aggressive Performance Duration at .050": 218/228 114 Lobe Center Angle with a 109 Intake Centerline Lift with 1.8 Rocker Arm Ratio: .594"/.585" Recommended Displacement: 6.2 Liter Engines Cylinder Heads: Gen 5 LT Recommended Compression Ratio: 9.50-10.5:1 Recommended Headers: Stock Manifolds, 1 3/4" - 1 7/8" Headers Recommended Stall Converter: Stock Recommended Rear Axle Ratio: 2.85-3.90 NOTE: Requires use of Cam Motion VVT Phaser 4 degree Limiter Block The TITAN I Gen 5 LT camshaft is designed for mild street performance in cars using 6.2 liter LT engines. The TITAN I Gen 5 LT cam will have a mild performance idle and strong low end to midrange power. This camshaft will work well in completely stock vehicles but will enjoy performance benefits when used with headers, high flow exhaust and increased stall speed torque converter and high flow intake systems. Note that this will NOT have a loope de doop... but I would select this as optimal. Please remember, that anything bigger is going to need the red line raised and at some point the rod bolts become suspect 6800 to 7200, depending on cam, sure the red line can be set lower but you would be falling off cam during the shift... but you already said performace is not the number one goal. http://www.cammotion.com/gen-5-lt-ca...formance-cams/
09-06-2019, 03:24 PM | #8 | |
https://www.ebay.com/itm/Chevrolet-C...-/253486978597
09-06-2019, 07:29 PM | #9 | |
2016 NFG 1SS A8
09-07-2019, 01:38 AM | #10 |
Yes I saw you said C6 and since this is a LT1, I limited my comment about LT1 factory manifolds / headers flows. I've listed my opinion above. I don't know anything about c6 at all.
if the base C7 outlet is bigger than 2.1" ID how are you determining they flow poorly, just asking. . I have no idea if there are different C7 manifolds but take your word for it. I looked at a ported C7 don't know if there are different types and the entrance is 2". So say stock unported is 1.8 what is the Camaro 1.6 or even smaller (I can measure it ) I did post when I took mine off. So if the tube size on the Vette is way bigger and the exit is way way way way bigger, why does it flow less? So I'll just leave it at that, IMO the Vette manifold flows better under the conditions listed above, but due to the tri-Y design and longer tubes, NA with mild cam the Camaro manifolds probably perform better over the RPM range of intended application. Neither works well with big cam, once again IMO. https://www.gmpartsstore.com/v-2018-...haust-manifold It would seem the C7 Z06 and C7 base take the same gasket and exhaust shield. So outside of the stainless material and maybe some bigger passages with thinner walls. They are very similar (base on gaskets and shields. https://www.gmpartsstore.com/v-2018-...haust-manifold visual the ZR1 manifold is at least similar: https://www.gmperformancemotor.com/category/GVLT.html
09-07-2019, 10:45 AM | #11 |
Point remains that the OP could cam his car with stock exhaust, it will just be leaving some power on the table. It definitely goes against the grain of how most mod their cars. Honestly he would be better off installing a supercharger.
2016 NFG 1SS A8
09-07-2019, 11:16 AM | #12 | |
Drives: Black Join Date: Jan 2017
Hose A- 50ft 2” diameter hose Hose B - 50ft 3” diameter hose in which in the middle there is a few inches of 2” diameter (aka a 2” restriction”) Despite what you’d think, hose B would crush hose A in flow. It’s not just the diameter, its the length at that diameter |
09-07-2019, 12:41 PM | #13 |
BL1ZZRD
Cost is a factor otherwise I’d be going FI all the way!
09-07-2019, 12:49 PM | #14 | ||
The Cam Motion base cam would make the best choice given the build but it is not lumpy. The Hot cam would have a define lump and even though I think it is way too big, GM designed it for this application. The power curve actaully looks spot on too. I don't know as obviously it is a BIG duration small LSA cam.
