08-31-2019, 09:15 PM | #1 |
Drives: 2016 D1X Procharged Black 1SS Join Date: Jun 2018
Holley Hi Ram Question
Anyone install a hi-ram and didnt have to cut the trim piece right above the IM or mess with the firewall? If so i would like to know. Im looking to get a hi ram but dont want to hack up anything if i dont have to.
09-04-2019, 01:27 PM | #2 |
Anyone? Really want to get a Hi-ram soon but still on the fence...
09-04-2019, 04:16 PM | #3 |
Drives: 2016 2SS 8AT Join Date: May 2018
I would like to do one as well but I think the silence here should speak loudly. You will have to cut your firewall to fit it and the stock hood will not fit without cutting. I dont believe there is any getting around that.
09-05-2019, 12:11 AM | #4 |
Well the hood clearance issue, i know was unavoidable. I got the COPO hood from Anderson Composites for that. I was just hoping i would be able to avoid messing with the firewall and cutting trim pieces if i could.
05-02-2020, 09:07 PM | #5 |
Drives: 2018 1SS M6 Join Date: Feb 2018
resurrecting this thread. Looking to do a high ram. I know i have to cut the hood. The cowl trim piece i think is what hes referring to as firewall part. Is that pretty easy to cut? anyone have pics? also is there any other modifications you need to do to fit the high ram?
2018 1SS M6 - OTR intake, HI Ram intake, Ceramic Coated TSP Headers Catless, AWE Touring Axle-Back, Flex Fuel, Pray Performace stage 3 cam, TSP ported heads, Pray Ported 95MM TB and Ported HI-RAM. SJM Line-Lock. F14 Drag Pack 17's with front skinnies. Tuned by Pray Performance.
05-02-2020, 09:50 PM | #6 |
Drives: SS 6 speed of course Join Date: Jan 2016
I've seen a square cutout of this piece, it is plastic, I don't know how far back any metal is. Looks like a tunnel ram setup from the olddays, like EVEYBODY knows what your packing.
There was a Vette with a highram at the last get together, man was that bad action looking. This guy just bent most of it up. https://www.camaro6.com/forums/showt...493649&page=11 here is one with a cut https://www.camaro6.com/forums/showt...493649&page=14
