Old 09-18-2019, 07:18 PM   #29
wintertopdown
Drives: 22 Convertible V8 LT1
Originally Posted by Emoto View Post
How hard are they to remove? Are they bolted in place, or what?
They come off easily but you have to lay down on the ground
wintertopdown is offline   Reply With Quote
Old 09-18-2019, 07:48 PM   #30
VQ35DE
Drives: 2013 / 2SS / RS / L99
Love my Race Ramps.
VQ35DE is offline   Reply With Quote
Old 09-20-2019, 03:07 PM   #31
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Originally Posted by NeverDie View Post
Just FYI, not everyone has to go "deep in debt" to buy a $400 product. ROFL
And if that's the case, one shouldn't own this type of vehicle in the first place.
Agreed ^^^^^ I paid $300+ for 10" Race Ramps ( 3 years ago) that are light, long and work for my 3 cars . I pay more than $400 for a monthly commuter pass and parking ( so in comparison, not a lot of $ for the ramps).
The only down side I see with foam ramps is you don't want to drop them near the leading edge, you may damage them. As well, I always sweep that area of driveway to clear any pebbles, they'll dent the foam. Mine look brand new after 30 +/- uses.
I slide a 5 gallon bucket under the car to capture all 10 quarts. Easy peasy...
Old 09-21-2019, 08:06 AM   #32
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
After having watched this video years ago I made the same extenders and to this day I still have and use them regularly. They are not quite as convenient as just having the long Race Ramps but they work and easy to build.
Dysan911 is offline   Reply With Quote
Old 09-23-2019, 08:12 AM   #33
Tyrolblue67
Drives: 2019 ZL1 Camaro
Can you please provide the Race Ramps model number that you have?
I presume they work for a ZL1?
I'm looking to purchase a set for oil changes on my ZL1.
I used the Race Ramp online calculator and they provide many model numbers that are possibilities.
I'm "thinking" the 56-race-ramp model would work?
I just would like to confirm what works.
Thanks,
Tyrolblue67
Tyrolblue67 is offline   Reply With Quote
Old 09-23-2019, 08:31 AM   #34
Chutzpah
Chutzpah's Avatar
These are the ramps I have. I’ll send a pic of the Z approach angle later today or tomorrow.
Old 09-23-2019, 12:26 PM   #35
Tyrolblue67
Thanks for the info.
I appreciate it.
Tyrolblue67
Old 09-23-2019, 12:34 PM   #36
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
I have the 56" Ramp Ramps that I paid $235 for off Amazon and my ZL1 drives up on them perfectly with no issues.
djfury05 is offline   Reply With Quote
Old 09-23-2019, 01:30 PM   #37
Tyrolblue67
Do you have the model number?
Tyrolblue67
Old 09-23-2019, 05:12 PM   #38
Chutzpah
Chutzpah's Avatar
I appreciate it.
Tyrolblue67
As promised, here are the pics. As a note, for the ramps I have, you’ll either need use a small piece of carpet or rubber matting @ ~ 3/8” to the leading edge of the ramps. Otherwise, you may scrape the underside rubber air deflectors.
Good luck with whatever you choose.
Old 09-23-2019, 10:19 PM   #39
djfury05
djfury05's Avatar
Tyrolblue67
https://www.amazon.com/Race-Ramps-RR...gateway&sr=8-2
Old 09-24-2019, 07:07 AM   #40
Dysan911
Dysan911's Avatar
So if the 67in barely clears the lower air deflectors under the splitter, how the heck to do the 57in work?
Old 09-24-2019, 07:33 AM   #41
Tyrolblue67
Thank you.
Tyrolblue67
Old 09-25-2019, 06:23 AM   #42
Chutzpah
Chutzpah's Avatar
The angle of the 57” ramps @ 8” tall is exactly the same as 67” ramps @ 10” tall (10.8 degrees)
The only benefit of longer ramps is overall height.
