03-02-2021, 09:54 PM | #1 |
Drives: A Vette Join Date: Jan 2020
Toyo Proxes R888R
Looking into a set of these tires for the rear while running a summer performance tire up front like a Continental ECS or Michelin PS4S.
How do you guys like these Toyo R888R tires? What kind of mileage can I expect out of them on average with mainly normal drives and some fun runs here and there? How do they handle rain if you happen to get caught in it? Heard they are noisy but is it honestly that bad and unbearable? Maybe only having a set in the rear will be less noisy versus having it on all four corners. How is the grip when heavy on the throttle from a standstill and slow rolling speeds anywhere from 0-40 mph? Anyone with experiences with these tires please share. Thanks in advance for answering all questions. |
03-02-2021, 11:59 PM | #2 |
Drives: '21 ZL1 A10 '08 SRT10 Join Date: Apr 2019
Personally I am not a fan of running miss-matched rubber on any of my cars. Why not do all 4?
03-03-2021, 12:27 AM | #3 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Running R888R rear and PS4S front seems to have some benefits for street driving and straight line performance with a ZL1 or similar cars, the R888R has the maximum dry grip for launching hard and the PS4S will help if you hit some water unexpectedly like the sprinkler runoff from houses in canyons near my house in LA hills. R888R are not good in water.
For combo street, canyon carving and some circuit track use, definitely go PS4S, GY SC3 or R888R on all 4. |
03-03-2021, 07:10 AM | #4 |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
I can tell you that I have been extremely disappointed with the 888Rs on my ZL1 1LE. They have better cold grip that the 3Rs but they were like ice skates at operating temp. I tried a wide array of hot tire temps from 32-39 psi and the car was always a handful. I went back to the 3Rs and letting them warm up first before going hard I was able to shave 6 seconds off my lap times at Sebring on the same weekend. Lap times went from 2:26-2:28s to 2:20-2:22s. The car was much more stable and I wasn't fighting the car at all during the laps. The 3Rs also gave me good grip through 2 days where the 888Rs would be ok for most of the first day and then really fall off the second day. Maybe they are better for straight line launches but I wouldn't recommend them for road course or track use.
And yes, they are VERY noisy. |
03-03-2021, 07:31 AM | #5 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
Simple - Michelin PS4S for the Street / GY3R for the Track.
#SAVETHEMANUALS
03-03-2021, 08:10 AM | #6 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
What is the goal here? Straight line acceleration or road course?
03-03-2021, 08:13 AM | #7 |
I would do this setup to help disperse some of the wet out of the way with the summer performance tires up front and to cut down on some possible noise. Also I never had Toyos before so I'd want to see how they do in the rear first and if I truly like them then get all four next time if not than a different R compound in the rear. I'm mostly doing straight line stuff and not so much road course as well.
03-03-2021, 08:19 AM | #8 |
Mainly straight line. I know the R888Rs are more suited for road course and other R compound tires are for straight line but heard a lot of good things with the Toyos and seen folks use them in the rear as they put the power down better than some of the other R tires like Nitto from what I've seen.
03-03-2021, 08:23 AM | #9 | |
03-03-2021, 08:24 AM | #10 | |
03-03-2021, 08:36 AM | #11 | |
Interesting I rarely hear of the Toyos letting anyone down. But everyone has there preferences for which tire seemed to personally hook better for them. Bob down the street could have luck hooking better with the R888Rs while Tommy next door seems to hook better with a MT or a Nitto. It's almost like supplements in a sense that everyone's body chemistry is different and what supplement works for one person may not work for the other person. Maybe not the best analogy but you get what I'm saying. I think it's a matter of seeing how the Toyos work for my car and if not then try something else. But if the Toyos really hook good well then I guess don't fix it if it's not broken. |
03-03-2021, 08:48 AM | #12 | |
As cool looking as the 555g2s are paired with the 555r2 I'd have to use the Contis instead because according to discount tires website the G2s are a heavier tire. 5 pounds heavier per tire than the conti ECS. So I'd rather go with the lighter tire. The ECS tires are good and I'm sure they are better than the G2s. |
03-03-2021, 08:52 AM | #13 | |
Kevin
03-03-2021, 08:55 AM | #14 |
The tread pattern doesn't seem to be welcoming for the wet I can see that. Have you tried these tires in the wet before? Are these tires the white knuckleling the steering wheel and praying you make it home type?
Thread Tools | |
