Old 03-03-2021, 09:50 AM   #15
foshjowler
foshjowler's Avatar
Drives: 2017 Camaro 2.0T, 91 Miata
To be fair, 305 mm is 12" and the wheel is 11" wide, so it is pinched a little bit. The rear would be about the same. I don't know how the 3Rs actually measure, but I wouldn't be surprised if they run a little wider than 12"
305 BFG Rivals FTW
Youtube Channel
foshjowler is offline   Reply With Quote
Old 03-03-2021, 11:41 AM   #16
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
You sure about this pic? I know they will be slightly more narrow when mounted but that sure looks like more than normal. That looks more like two different tire sizes.
Another pic of the size issue taken of my tire sets. Confirms what the OP has originally posted. Tires are the same size and the mounted tire set are on stock rims:
breakskeet is offline   Reply With Quote
Old 03-03-2021, 02:50 PM   #17
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I think this is an optical illusion more than anything else. The unmounted stack is no more than 4 inches taller by my best guess just eyeballing the picture. If so that’s just one inch per tire. Which means 1/2 inch per side. I can see tires this wide pinching in a 1/2 inch per side once mounted. I’m just always amazed how wide these tires look once they are off the car.
476 rwhp/440 rwtq (sold)
Old 03-03-2021, 08:35 PM   #18
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
You can definitely put these tires on a wider wheel with likely good results - if you can fit them without rubbing. The hot setup on an NA miata is a 245 tire on 15x10's. 305's are almost 2.4" wider on a wheel only 1" wider. When I stack those 245 mounted wheels next to bare rubber, the mounted stack is a tad taller.
Pcormier66 is offline   Reply With Quote
Old 03-04-2021, 07:08 AM   #19
foshjowler
foshjowler's Avatar
I was debating for my Miata if I should go with 15x9 or get some over fenders and do 15x10. I'm still like a year out from having to worry about it, right now roll bar and seats are the priority for it so I can be able to track it. But it's still a debate I'm having with myself.
305 BFG Rivals FTW
Youtube Channel
Old 03-05-2021, 02:30 PM   #20
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
Personally, I like the look of flares. This is my dedicated Track Miata. She is being ignored while I have a blast in my ZLE.
Old 03-07-2021, 07:59 AM   #21
foshjowler
foshjowler's Avatar
I’m on the side of getting them, especially since I bought it for $800 pre-crashed. It’s by no means worth keeping in any sort of nice condition.
305 BFG Rivals FTW
Youtube Channel
