03-04-2020, 01:12 PM | #1 |
Drives: 2012SS Join Date: Aug 2018
AGP Turbo oil scavenge pump question.
I see people say the oil would get into the exhaust if there were problems with oil scavenging.
Could oil get into intake instead if the pump was failing or there were some problems with the drain lines?
2012 2ss A6, AGP TT kit, 54/57 BallB, AUS 1400cc injectors, Meth, 1LE suspension, HRE FF01 20x9" front, 20x10.5 rear.
03-04-2020, 01:22 PM | #2 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
Not that I can think of. Most likely is blow-by. Do you have catch can or some sort of crankcase ventilation setup?
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
03-04-2020, 02:01 PM | #3 |
I had PCV system mounted incorrectly so that there was pressure in the crankcase under boost.
A lot of oil was coming out of the blow-off valve. Now it vents into atmosphere via AGP catch can. And I want to find out if the the only reason for oil under car was blowby or any other install related things could add to this.
03-04-2020, 02:23 PM | #4 | |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
absolutely. you will see oil in the cold side even when the scavenge pump is working correctly.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
03-04-2020, 04:12 PM | #5 | |
Drives: All things Turbocharged Join Date: Dec 2010
BUT to answer your original question- Yes, oil can leak into the compressor side of a turbo if the turbo is filling up with oil and pressurizing, it will squeeze out both sides. And once solved, that will also take a while to clean it all out. |
Thread Tools | |
