02-28-2020, 03:32 PM | #1 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Journal V Ball bearing
What's the deal with so many people avoiding Journal. Do ball really spool up that much faster? Are there other concerns I'm missing? Cause if that's the only issue, unless your professional racing for a living, it seems like a minor issue.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
02-28-2020, 04:20 PM | #2 |
Drives: All things Turbocharged Join Date: Dec 2010
Really depends. Ballbearing turbos do spool up quicker. But Depending on how big your engine is in relation to your turbo, it might not be noticable. Like a 376 w/ (2) 5457 JB turbos it's not an issue. But you go up to a pair of 6565 turbos and you for sure want ballbearing on a 376. Also a major factor is transmission. An automatic car with a stall will never notice lag because it slips past those RPM right up to where the turbos are spooled up. Where a manual transmission has to re-spool big turbos every time you shift, so ballbearings and a big CID engine are best. It's just a big balancing act depending on your equipment.
02-28-2020, 05:48 PM | #3 | |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
02-28-2020, 10:33 PM | #4 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I've compared tunes several times, but I just cant figure it out.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-29-2020, 06:25 AM | #5 |
The NLS parameters are not accessible in the tune. However, some other related settings can be modified in the tune to tweak the NLS like delays and such. But, there is no specific NLS section in the tune.
