07-15-2019, 07:02 AM | #15 |
Drives: None at the moment Join Date: May 2018
Get the PDR if nothing more than for a built in dash cam. Use your EYES and common sense for the forward collision warning...
07-15-2019, 08:24 AM | #16 |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Go for the FCA you can always get a GoPro. My Tacoma PRO has a standard built in GoPro mount on the inside of my windshield. How cool is that. Maybe get a mount like that. The GoPro's are better anyway.
Here is the quality of the PDR...not good. But it does have a lot of cool stats on it. So there's that.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
07-15-2019, 09:15 AM | #17 | |
Drives: 2020 Camaro ZL1 (A10, crush) Join Date: Jun 2019
Regarding Track use, my original comment "I will not track the car much if ever" was mainly referring to my plans for the first few years of ownership, I am not buying the car to track it immediately, never is a long time. Main use will be driving it every opportunity I get. All that may change of course once I get behind the wheel and given the fact I am only 45 minutes away from Dominion Raceway |
07-15-2019, 09:45 AM | #18 |
Drives: 2019 Camaro ZL1 Join Date: May 2019
I have a 2019 that I bought off the lot. It has the PDR which the salesman wasn't aware of since he said it has the FCA. Then days later I see the memory car slot and realized I had PDR.
I daily drive this car and I have used the PDR once to test it out. It's pretty cool and all, but I would have rather had FCA. I am assuming FCA also detects objects in front of the car when parking such as parking stops. Is this correct? I doubt I will ever track my car either. Maybe the drag strip though. I can't risk crashing my daily driver on a track. |
07-15-2019, 10:11 AM | #19 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
You need to sign up for TNIA at Dominion in Aug. Will be there! I was the only Camaro there in June.
07-15-2019, 10:16 AM | #20 |
As some of you may know, the problem with the FCA is that it operates with cameras. I dont know where the camera is on the camaro "might be the same one used for the PDR", but on my wife's Nissan they are in the bumper exposed to the elements. And every time there is any inclement weather they don't operate. I mean a simple rain shower will cause them to go inoperable. Which means the cruise control doesn't operate either! I understand the connection and why, I just think it is stupid. Just food for thought!
07-15-2019, 10:18 AM | #21 |
I won't have the car yet, unless I can find a 2019 that meets my requirements otherwise I'm about to order a 2020, but I will definitely try and stop by to check it out and observe.
07-15-2019, 10:31 AM | #22 |
Order it, then get exactly what you want and not stuff you don't.
Current ride
07-15-2019, 11:13 AM | #23 |
Yes, it would make sense the FCA camera is the same camera or is in the same location as the PDR camera since they are mutually exclusive.
That begs the question, how well does the FCA work on the Camaro? I assume I'll be able to creep up to objects I cannot see from the drivers seat like a curb and get a warning before the car makes contact? |
07-15-2019, 02:20 PM | #24 |
Drives: 2019 2SS Join Date: Mar 2018
Correct me if I am wrong but isn't FCA just a warning? I have 19 2SS and it is equipped with FCA the only time it works is when I am getting close the car in front of me too fast. Then it just beeps and flashes some red light in head up display.
Also there is a button on the steering wheel that lets you change the sensitivity. So if you are on the highway it shows whether you are maintaining safe travelling distance or not. If you do, it shows a little green car icon in the dash and head up display if not it show an orange car icon. If you ask me it is pretty useless feature and in your case $1300 pdr isn't justifiable either. If I were you I wouldn't opt for pdr and spend that money (probably costs less than half) to have a shop install dash cams on both windshield and rear window that are hooked up to the battery so you will have parking mode functionality too, just like Tesla sentry mode but not as good of course. |
07-15-2019, 03:03 PM | #25 |
Drives: 2019 CLA 450 Mercedes Join Date: May 2016
I am asking for information on the FCA. I know that in our MKT and on the AMG, the FCA system gives a strong alert (visual, audio and shakes seat/wheel on Lincoln only), tensions the seat belts and pre-loads the brakes. The AMG will actually start applying the brakes (a little newer). Both of these systems work with sensors that are placed in the front bumper. Neither has a camera.
I was curious about the Camaro's FCA system stopping to function in bad weather. Also, I know that where the PDR camera sits would not be the best for any type of parking aid (pulling in).
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
07-15-2019, 03:11 PM | #26 |
Drives: 2018 ZL1 Camaro Join Date: Mar 2019
Is FCA only on auto Trans?
07-16-2019, 12:09 AM | #27 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I rented a 2019 2SS on vacation earlier this year and was surprised to find out the car had FCA within the first 10 minutes while accelerating to clear a yellow light. That was on the default most conservative setting and I was not at all concerned about having an accident unlike the car's computers! I turned it off after that...not sure if there would be enough time to react to a real incident with FCA on a more aggressive setting. Last edited by cdrptrks; 06-07-2020 at 07:11 PM. |
07-16-2019, 08:50 AM | #28 |
I originally misunderstood the functionality of FCA.
After a few conversations with folks who have this feature, this is how I understand FCA works (for the camaro): it has a forward facing camera (perhaps the same camera for PDR), you select 1 of 3 predefined distances to monitor, when traveling FCA will monitor the area within the distance you selected, if you approach or close in on an object at a rate the computer determines is unsafe, a visual and/or audio warning goes off. FCA will NOT apply the brakes or attempt to stop the vehicle in any way. That's up the the driver Based on this information, FCA is not what I originally thought and hoping it was, therefore I will get the PDR when placing my 2020 ZL1 order. Personally I feel I'll get more use/enjoyment out of PDR. Thanks again. Last edited by zl1_fan; 07-16-2019 at 09:27 AM. Reason: additional info |
