08-03-2019, 07:54 AM | #29 |
I'm at 28 cold. They heat up to about 30 and I get no warning lights. I'm actually going to try 26 next time out.
08-03-2019, 05:33 PM | #30 |
28-30 seems to be where they ride the best.
2016 NFG 1SS A8
08-04-2019, 10:15 PM | #31 |
Did a couple 0-100's yesterday evening. Not bad for 30psi mid summer. I'm sure it will go into the 6's this fall with the tires lowerd to 26 psi.
2016 NFG 1SS A8
03-12-2020, 09:16 AM | #32 |
Made a couple pulls last fall in cooler weather. Tires are pretty much too the wear bars. Pretty confident I can go mid 6's with a fresh set because I was spinning some on this 6.8 run.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 03-13-2020 at 11:05 AM. |
03-12-2020, 02:15 PM | #33 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
My best so far this is pisc stock setup with meth a10 2ss. toyos 315/30/20. I use launch control. Keeps it fro spinning so much from the stab. launch at 800. You can feel it kill power and see it kill timing in the log to stop the spinni ng and it does but as you get close to shift in first starts spinning again and of course it spins on the shift. Sometimes not too bad a few times pretty bad. On the street of course and the weather was cooler 58 i think da was about 200 ft. I got a set of the nto5rs drag 315 35 but they are just no better than the toyos. maybe if i smoked them real hard, never tried that just slight burn out. I would love to get a better hook. What do you think would a 345 help? They will fit but alas not as soft. I wonder if the 555rs might be better than the nto5r? Anyway good running car king. Always enjoy reading your post
03-13-2020, 10:47 AM | #34 | |
I believe tire height and increased side wall becomes more important then width once you are up to a 305. You might be at a point where it's time to consider a 305/40/17 for more side wall. I know I am right on the cusp of needing to make the switch as well. Thanks!
2016 NFG 1SS A8
03-13-2020, 12:25 PM | #35 |
Nice runs!
If you're not on a prepped track....us supercharged guys cannot stab it from a dig..not even on a DR. You gotta roll into it. I don't have a 0-100, but have a 0-103.56 @7.069 at around +1700DA
03-13-2020, 01:36 PM | #36 | |
03-16-2020, 11:10 AM | #37 |
Drives: A10 ZL1 Join Date: Mar 2018
I tried MT 305/35/20’s and got Stabilitrak, ABS, wrench error message. I sent them back and have since rerouted the wiring harness. I may go with Toyo888R’s. If I use a 5mm spacer should the 315/30/20 work without rubbing?
03-16-2020, 11:16 AM | #38 | |
https://www.camaro6.com/forums/showt...6#post10740736
03-16-2020, 11:47 AM | #39 |
Thank you very much for the info!
03-16-2020, 11:04 PM | #40 | |
Camaro6 newbie
Drives: 2020 Riverside Blue Metallic 2SS Join Date: Feb 2020
03-17-2020, 04:47 AM | #41 |
I run the toyos 315 30 20 on 10.5 rim with 40 off set no problems but I did do the harness mod just to be safe
03-17-2020, 06:36 AM | #42 |
They do. I did move the drivers side harness as a precaution though.
