Old 04-22-2023, 07:23 AM   #1
bptuner
Drives: 2018 zl1
Track rotors and pads advise
Currently I'm running ZL1 stock rotors with Ferodo pads (DS1.11).
What is everyone's rotor upgrade of choice? looking for a little more brake to help late brake and set up the corners.
bptuner is offline   Reply With Quote
Old 04-22-2023, 08:15 AM   #2
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Originally Posted by bptuner View Post
Currently I'm running stock rotors with Ferodo pads.
Well I have Girodisc front rotors (4.8 pounds lighter per side rotating mass) and DTC70 Hawk Pads on front and DTC60 pads on rear (see first pic below). Braking is VERY VERY good. When NOT on track I use stock pads. I also installed BLACK WING brake air ducts (see second pic below) and that helps.
I upgraded the ZL1 calipers with vented brake pistons, silicone HI TEMP brake piston boots and stainless steel brake lines using WILWOO EXP 600 DOT4 brake fluid. I even CERAKOTE the calipers to handle the intense heat I was seeing on track days (about 450 degrees at the caliper). The YOUTUBE video BELOW in my signature is that EXACT set up at the track. THAT time is ALMOST a full second FASTER than the FAST time listed in the ROAD COURSE section for Eagles Canyon Raceway - 2.7 CCW Config - Decatur, TX. That is ALOT of difference and that is specifically what allows me to top 135MPH on the back straight PRIOR to braking for the 90 degree corner (you can see it on the video). Basically its what allows me to brake LATER than everybody else.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 04-22-2023, 01:55 PM   #3
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2021 ZL1 1LE A10
Loved my Hawk DTC’s. Trying G-locs next weekend at VIR after hearing good things. hawks can be a little tough on rotors but I don’t have a comparison, but will soon. Stock rotors for now but I did buy some dBA replacement rings. Only experience I have is bedding the new G-locs. The ZL1 stops as good as I’d hoped coming out of a Z06. Also have the Cadillac ducts above.
Link to rings - > https://goturbo.net/dba53916-1-dba-1...-rotor-53916-1
1997 Z28 Anniversary Edition SOLD
2004 GTO ORDER CANCELLED
2004 CTS-V SOLD
2005 CTS-V SOLD
2006 300C SRT-8 SOLD
2010 CTS-V SOLD
2012 CTS-V coupe SOLD
2013 ZL1 vert SOLD
2016 Callaway Z06 SOLD
2019 Z06 SOLD
"I lived my life by one motto.......mottos are for losers" cvp33
cvp33 is offline   Reply With Quote
Old 04-22-2023, 03:01 PM   #4
ColeD
ColeD's Avatar
Drives: Chevy Camaro
Doesn't the zl1 and ss 1le come with brake ducts already? Are the blackwings just beefier?
Is there also a weight difference between giro rotors and dba?
'22 2SS 1LE manual in Red Hot with Red seat belts, alloy pedals, PPF, catch can, and suede kneepads.
ColeD is offline   Reply With Quote
Old 04-22-2023, 03:22 PM   #5
sr71bb
sr71bb's Avatar
The black wing ducts are wider and they have a scoop that that picks up air slightly below the bottom of the chassis.
Retired Cars BELOW:
Old 04-22-2023, 03:27 PM   #6
sr71bb
sr71bb's Avatar
Yes there is The girodisc rotors are only 28 pounds mainly because the girodisc rotor hats are much lighter. DBA are replacement rings for the standard ZL1 rotor hub
Retired Cars BELOW:
Old 04-22-2023, 03:56 PM   #7
bptuner
Drives: 2018 zl1
I see the giro disc rotors lose about a half inch of surface area but have slots and better cooling posts. ZR1 felt like I was gonna go through the wind shield, I want that type of feeling back.
the DS1.11's are about 50% worn maybe they are glazed, they feel good just not OMG good. some have recommended new brake lines?? spiegler lines.
Old 04-23-2023, 08:28 AM   #8
bptuner
Drives: 2018 zl1
Is there a replacement hat that is lighter for stock rotors? You could match up to the DBA rings.
Ive heard DBA's overheat quickly.
Old 04-23-2023, 08:34 AM   #9
Shawnqa800720
Shawnqa800720's Avatar
Drives: 2018 1SS
I upgraded to the SS 1LE big brake kit because I was getting brake fade at some of the tighter tracks in my area. I also switched to Raybestos ST43 pads (expensive, but they really last) which was also a noticeable difference. I was already using Castrol SRF brake fluid, so the fade I was getting wasn't from overheating the fluid, but from the pads being overworked. The difference was better than I hoped as the brake fade is gone, but the brake power and feel is definitely better.
If making the choice, I do think the ZL1 caliper and rotor are worth the extra price and had I to do it over, I would go that route myself. The only thing I am unsure of is - do the ZL1 brakes allow an 18" rim?
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
Shawnqa800720 is offline   Reply With Quote
Old 04-23-2023, 09:07 AM   #10
sr71bb
sr71bb's Avatar
NO there is not. The design on the GIRODISC is such that the actually rotor hat is made out of lighter materials and is BIGGER than the hat on the stock ZL1 rotor. THAT way they maximized the weight savings. The overall diameter of the rotor though is still 390MM or 15.35 inches. What that means of course is the actual WIDTH of the rotor pad contact surface is slightly NARROWER. A FRONT girodisc rotor takes the same pad width as a SS 1LE setup.
The STOCK design relied heavily on the MASS of the rotor to help dissipate the heat during the braking process. The GIRODISC rotor has MORE cooling vanes and since it is almost 5 pounds lighter it DOES NOT require the same amount of energy to slow down or bring the rotor to a stop.
STOCK ZL1 rotors are NON-DIRECTIONAL and GIRODISC rotors ARE directional with a different part number for the driver and passenger side rotors.
Retired Cars BELOW:
Old 04-23-2023, 09:30 AM   #11
cvp33
America FVCK Yeah!
cvp33's Avatar
That would be incorrect. dBA rotors do not overheat more quickly than OEM. Where did you hear that?
2004 CTS-V SOLD
2005 CTS-V SOLD
2010 CTS-V SOLD
2013 ZL1 vert SOLD
2019 Z06 SOLD
Old 04-23-2023, 09:41 AM   #12
cvp33
America FVCK Yeah!
cvp33's Avatar
Apex 18’s fit for sure.
2004 CTS-V SOLD
2005 CTS-V SOLD
2010 CTS-V SOLD
2013 ZL1 vert SOLD
2019 Z06 SOLD
