Old 12-05-2018, 05:37 PM   #29
headgamez
Drives: 2018 Camaro ZL1
Originally Posted by DWR View Post
Anyone know of anything like this for the 1LE? It seems that no one has came up with a non-splicing method for installing amps/subs for this car (as we dont have a factory amp)
I have this.....
PAC Audio Speaker Connection Harness - APHGM02
headgamez is offline   Reply With Quote
Old 12-05-2018, 10:46 PM   #30
oOKhanhOo
Drives: 2018 SS 1LE
bump. Does this work with 1SS 1LE? because the 1SS 1LE does not have a factory amp, not even a non-bose amp
oOKhanhOo is offline   Reply With Quote
Old 12-06-2018, 01:30 PM   #31
headgamez
Not 100 percent sure...Maybe someone else can chime in??
Old 12-06-2018, 02:58 PM   #32
oOKhanhOo
Drives: 2018 SS 1LE
A member, “lfree11012”, confirmed to me that it does work with the 1SS 1LE.
Old 12-13-2018, 07:27 PM   #33
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
lfree11012 is offline   Reply With Quote
Old 12-21-2018, 06:53 PM   #34
KirkH
Originally Posted by lfree11012 View Post
THANK YOU THANK YOU THANK YOU for this video!
What a bitch this job is!!!
Old 12-30-2018, 10:32 PM   #35
WhyUMad1LE
Drives: 17 SS 1LE
So we now have three plug and play options w/o amplified chimes for the 2016-2018:
Anyone want to analyze the pros and cons? I was going to go with an LC7i but I might go for one of the last two options if it's worth it.
Old 12-31-2018, 08:32 AM   #36
SilverCamaroVert
Drives: 2019 LT3 RS Convertible
Is that the Axxess setup for non-bose? I was thinking this was for cars with Bose: https://axxessinterfaces.com/product/AX-DSP-MOST1
In my thinking, the Pac is a better price point with the optical, bass knob and harness included but requires a PC to program. The Axxess can be programmed with your phone in a parking lot if needed. That's pretty handy.
SilverCamaroVert is offline   Reply With Quote
Old 01-02-2019, 01:52 PM   #37
JaxChris
Correct. The subject is about Camaro's with the Bose amp on the MOST bus. You will need the Axxess AX-DSP-MOST1 bundle. That is 400-450$ depending on retailing right now and comes with the harnesses.
Also, the PAC module does not include the GM02 harness which is in addition to the purchase of the interface.
Old 01-02-2019, 06:50 PM   #38
SilverCamaroVert
Thanks for confirming. I'm working to design my system replacement and wanted to be sure.
Another thing I have noticed when comparing the Axxess to the PAC is the Axxess has separate 31 band eq's for front, rear and subwoofer as well as individual delay adjustment for all 4 speakers and a sub.
If the Axxess DSP's DSP is adequate for one's needs, I think it's a better module (on paper. I don't own either yet). If one is going to use a better DSP, the PAC is probably every bit as good or better because it includes the optical.
Old 01-05-2019, 04:31 AM   #39
JaxChris
If you plan to run an external, high feature DSP, then the PAC module wins when you plan to make use of the optical interface.
If you plan to skip the external DSP, then the Axxess has more built-in adjustment. The PAC only has 3-band EQ, versus the Axxess 31-band. This means you'll be able to better set bandpass where needed. The PAC module does automatically sum and adjust to a flat output, where the Axxess does not auto-eq a flat signal to remove the radios built-in rolloffs.
The biggest argument for running an external DSP with either of these units is that it doesn't provide enough pre-amps to run an active front stage. This means you'lll be limited to components with passive crossovers sharing the same RCA. I really wish Maestro AR made a MOST module. Then Rockford could sell a version like they do with the DSR1 for CANBUS cars. Rockford takes the 99$ Maestro AR and adds their 3.SIXTY DSP to make it a 250$ integration module with 8 RCA outputs -- but I wish they really provided 10 or more. The Maestro AR reserves the last 2 as sub, leaving 6 full range channels. If you dropped the center channel, and used 6.5" subwoofers for 2 of the 4 rear speakers, you could drive a fully active system from the module to one 8-channel amp (or two 4-channel amps if it mounts better in your tire well). With 10 channel output and proper selection, you could have 1 center, 8 side channels and 1 sub channel. The Rockford DSP is pretty well rated as well as a digital software driven solution.
But I digress. Since neither module has a plentiful set of outputs, and I wanted to spend extra to have ultimate control over my system, I would get the PAC module and a MiniDSP 8x12. It has 6 RCA inputs (perfect match), 1 SPDIF input (not needed with this solution) and 1 optical TOS.link input (excellent). With that I would use the PAC module for control chime, phonecalls and ANC blocking. I would use the MiniDSP for center channel creation, run full active for all 9 speakers, and set time alignment for proper staging to both the front seats (thank you center channel).
If you have played with the Bose system, it does an ok job and can hit lower frequencies than most factory systems can. The rub is that in the name of weight savings, GM used ANC for noise control and installed zero isolation or deadening material in the car. The Bose system with the right sub bass tracks playing (<70hz) causes the door panels to get very noisy. Instead of wasting the limited trunk space with subs I would do midbass woofers in the doors and subwoofers in the side rear pockets with fast rings to limit space behind those drivers. Then I would run a resonance test with some deep bass and mid bass tracks to identify where patches of matting are needed other than immediately around the speaker mounts. I'd also look at padding the clip locations on the rear panels, doors panels, and mat most of the rear deck -- along with some better felt tape along the seems where the rear deck cover likes to rub and rattle most.
Give the subs 100 watts, woofers 75 watts, drivers 50 watts and tweeters 35 watts (I don't like a lot of tweeter at my age) in a combination of mini class-D amps sharing a d-block for power and ground with the DSP and integration module on a single board that can tie down in the tire well.
When you're full active, you don't use any filters on your amps, because you are doing highpass, lowpass and bandpass from the DSP. This means the amp works less only amplifying the signal you want on each channel and you don't need higher end amps with any extra features. This allows for very compact, low draw amps to just spit out watts.
Good luck.
Old 01-05-2019, 04:51 PM   #40
drfeelgood
drfeelgood's Avatar
Drives: 2017 ZL1 Convertible A10
Good luck.
Chris, are you in Jacksonville? I was born and raised there. What audio shop do you own/work at?
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq)
'17 Maserati Levante- STOCK
drfeelgood is offline   Reply With Quote
Old 01-06-2019, 10:31 PM   #41
JaxChris
Jacksonville is the place I lived in the longest and where I was when I made my first online name over 20 years ago. Never worked in the business, just been a customer of the industry for as long as I've been online. =)
Old 01-10-2019, 12:41 AM   #42
oOKhanhOo
Drives: 2018 SS 1LE
I can confirm that the PAC AP4-GM61 WORKS with the 1SS 1LE. It also gives out center/sub channel signal despite not having neither of those from factory.
