01-05-2016, 11:43 AM | #1 |
Drives: 2018 2SS Camaro Hot Wheels Edition Join Date: Sep 2015
Update: USB Ports & Apple CAR PLAY Not Working......Fixed
UPDATE:
As everybody knows, my apple car play quit working over the weekend. I took my car into the dealer this morning. Well, there was a reason it wasn't working. Both USB ports weren't working. So, if the USB ports don't work I can't hook up the iphone 6s and no apple carplay. We tried other cables into the USB ports but still no response. So the service technician at the dealership simply reset the actual main car battery. Once, he did that everything worked. We just had to pair up the devices again. So, problem solved. Now, this might be just a quick fix, for now. If it happens again (hopefully it won't) the USB ports plugging into the cars main computer will have to be checked for errors. I'm Posting this information in case anybody else runs into their USB ports in their Camaros stop working. Thanks to everyone at Pat O' Brien Chevrolet including James, Jordan, Melissa, Don and Jeff for helping me out with this issue! You guys are AWESOME!!!!!!!
Zack46
2018 Camaro 2SS Orange Crush Hot Wheels Limited Edition Power Sunroof, 8 Speed Auto/Remote Start, NPP Exhaust Production Sequence Number 98 NEOCC Camaro Club Member Former Ride: 2016 Camaro 2LT RS V6 Hyper Blue Metallic |
01-05-2016, 11:47 AM | #2 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Interesting....thanks for the info. I noticed this morning when my phone was connected via Bluetooth, under the Media tab, states no media available. Have to check that out later, hopefully not an issue that cannot fix!
01-05-2016, 12:12 PM | #3 |
Camaro Fan
So in other words, I need to reboot my car like my computer to get things to work again LOL
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15 3800 Status: 10/13/15 VIN #116519 4200 Status: 12/19/15 Delivered : 12/28/15 |
01-05-2016, 12:16 PM | #4 |
Retired from Car mfrs....
A reboot of the car is called "the GM global reset" google it.
It is done this way: Take off both batt cables and touch them together, this drains all the capacitors that still hold energy even when you pull the neg cable for 10 min. If this procedure unnerves you, pull the neg cable and let it sit overnight, the caps then drain slowly. And because the settings are held in NVRAM, very few of them go away on a reset. |
01-05-2016, 12:19 PM | #5 | |
Zack46
03-23-2017, 06:58 PM | #6 |
My USB ports just quit working as well. Does this reset, reset all car settings?
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
03-26-2017, 05:27 PM | #7 |
I just performed the "GM global reset" steps explained earlier. Solved my issue as well, and all settings were retained as normal.
Formerly owner of:
04-02-2017, 07:01 PM | #8 |
Drives: 2016 V6 Camaro 2LT RS Join Date: Dec 2016
After installing the footwell lighting kit, my USB ports went out. No charging nor Android functions. After a reading the Gen5DIY instructions to install the footwell lighting kit, I discovered that it could be the HMI module for the stereo. Which was on the panel I dropped for the footwell lighting installation. So, I dropped the panel back down & pushed in every connector on the HMI module. None of them clicked, but it did work. Very odd that the ports just magically worked again. Fuses & the removing/touching the battery terminals did nothing for me. I'm glad I checked the HMI.
04-05-2017, 09:20 AM | #9 | |
Drives: 16 black on black camaro rs Join Date: Mar 2017
04-05-2017, 11:53 AM | #10 |
You have to be a bit careful here, particularly if you installed any kind of aftermarket audio with a large cap. Shorting a cap can definitely damage it due to the sudden current spike.
01-11-2019, 01:16 PM | #11 |
Drives: 2018 Camaro RS 3.6 V6 Black Join Date: Jan 2019
I have the same issue on my Chevy Camaro. Both USB doors don't work.
How long the battery cables have to remain disconnected? Both cables or only the negative? Otherwise, I will go to the Chevy dealer and will see if it start to work again. The car is under warranty so is better if they do this operation. Thanks for the info.
Flavio - Italy
01-18-2019, 12:27 PM | #12 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
I get an issue that may be related. From time to time, it seems like my USB ports stop working, I keep a tiny thumb drive plugged into one of the ports for mp3 music. When mine stop working I unplug the USB drive and plug it right back in. This brings them back to life. I never had to do the battery cables fix.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
01-18-2019, 01:23 PM | #13 | |
Sounds good!!
Flavio - Italy
01-18-2019, 03:46 PM | #14 |
Drives: 2016 2SS A8 Convertible Join Date: Aug 2010
Yep. I had the same problem last summer. Did the global reset. No trouble since
