07-16-2023, 02:44 PM | #1 |
DSX idler bracket
My blower pulley is 2.75 and I want to change to 2.625 to generate a bit more torque on the hit. I've lowered the shifts to 6500 to lower blower speed.. The belt is not slipping now but I'm thinking it might slip with 2.65 . Kong says an 8-rib belt like a Gates should work if I use a DSX idler bracket to shorten the distance to the pulley. I don't know this bracket. Anyone use it?
https://dsxtuning.com/products/lt4-l...bracket-system
'20 ZL1 1LE A10,
07-17-2023, 11:55 AM | #2 |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
It works as advertised.
07-17-2023, 03:20 PM | #3 |
Drives: 2018 Camaro ZL1 A10 Join Date: Feb 2022
Make sure that you get the anodized ones, otherwise the belt will turn grey
07-17-2023, 04:59 PM | #4 |
'20 ZL1 1LE A10,
