01-10-2019, 04:23 PM | #1 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2018
Brake Fluid Amount
I've dug around on here for awhile and I keep seeing different amounts from some people (unless I am reading incorrectly) so I'm going to come right out and ask.
I am getting my brake fluid changed in my 2018 SS 1LE for some up coming track days and want to know how much brake fluid to get. The most common answer I found is 1 liter so I bought three 500ml bottles of Motul RBF 660 so that gives me 1 liter and a half to work with but that will that be enough to get through a full brake flush/refill
2018 Camaro 1SS 1LE
01-10-2019, 04:28 PM | #2 |
i was told a 2 big bottles of castrol srf is enough and you will have like 4/5 of the second bottle left lol
01-10-2019, 05:45 PM | #3 |
That should be 2 liters then from what I am seeing
2018 Camaro 1SS 1LE
01-10-2019, 06:26 PM | #4 |
well my buddy said since i gotta get mine flushed 1 liter for a full system and another one just in case so you should be good
i used motul 600 a few years ago but was told the castrol stuff is better so gonna flush and refill with that this month
01-10-2019, 07:47 PM | #5 |
Drives: '18 1SS 1LE Join Date: Sep 2017
The BG brake fluid exchange machine at work uses a 2qt jug.
'18 1SS 1LE Black, PDR
01-11-2019, 08:45 AM | #6 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Every time I do mine I end up only needing 0.9L for a thorough flush with my Motive bleeder. If you're not paying attention to when the old fluid is done purging through each bleeder then you'll use more.
01-11-2019, 10:20 AM | #7 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I can also do the full car in a little less than 1 L doing the pedal apply method.
Use the clearest line you can on the caliper to make it easier to see the fluid color change. Can also use a syringe to get as much old fluid out of the reservoir before adding the new fluid to make the fluid color change less blended.
2017 SS 1LE.
01-11-2019, 10:45 AM | #8 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Flushing fresh fluid with expensive fresh is such a headache
I make sure I have 2L to ensure it's all out |
01-11-2019, 11:19 AM | #9 |
Awesome, thank you all, I made sure I got 2 liters of Motul RBF 660 on the way. I did see where Castrol SPF seemed to be another high choice as well so depending how I like the Motul's, I'll switch to Castrol.
I am looking at maybe doing 3 track days inside of 35 days so the brakes are going to get a workout for sure
2018 Camaro 1SS 1LE
12-20-2023, 02:50 PM | #10 |
Thanks for this tip! I know it's 4 years later, but a great idea as I will be tackling this job soon.
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
12-21-2023, 12:30 PM | #11 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
