Old 02-25-2020, 05:43 PM   #1
Jason16ss
Drives: 2016 SS camaro
No start
2016 SS wont start brand new battery when i try to start the car it saying action required shift to park the car is clearly in park volts is showing good everything works windows sunroof radio any suggestions
Jason16ss is offline   Reply With Quote
Old 02-25-2020, 05:44 PM   #2
Tricksta
Tricksta's Avatar
Drives: 2018 ZL1 A10
Have you tried playing around with the shifter to see if it will cause the notice to go away?
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust
Tricksta is offline   Reply With Quote
Old 02-25-2020, 07:14 PM   #3
Jason16ss
Yes still no go ive been trying for hours
Old 02-25-2020, 07:23 PM   #4
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Check your fuses just in case but to me it sounds like a PRNDL switch. Likely a switch in that assembly if those 10 speeds have that. Or whatever tells the computer the car is in park. Could also be in the wiring.
Old 02-25-2020, 07:28 PM   #5
Trochoidal
Drives: 2017 Camaro 2SS A8
Yeah I was about to say the same thing Scottyz just posted. Did you jump the car before replacing battery?
Old 02-25-2020, 07:33 PM   #6
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
There are several threads on defective shifters and one instance of a bad TCM.
Sweptwing is offline   Reply With Quote
Old 02-25-2020, 07:45 PM   #7
Jason16ss
The car is fairly new to me I bought it used and I've had nothing but problems with it before this it was spazzing out and you were just disconnect the battery and then put it back on in the car would start but now it just says shift the park and it won't start and I've never jumped the car
Old 02-25-2020, 08:01 PM   #8
Sweptwing
Sweptwing's Avatar
The shifter and or TCM should be covered under the 5yr/60k warranty if it’s still valid.
Old 02-25-2020, 08:36 PM   #9
Jason16ss
Even with longtubes on the car ?no tune
Old 02-25-2020, 09:12 PM   #10
Sweptwing
Sweptwing's Avatar
Some dealerships are more “mod friendly” than others I would ask around.
Good luck on getting to the problem.
Old 02-26-2020, 01:18 AM   #11
GroundhogSS
GroundhogSS's Avatar
Yeah, I had that problem last year. The dealer had to replace the whole shifter. The sensor is built into the mechanism. No problems since.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
Old 02-27-2020, 09:07 PM   #12
Southwest
Drives: ‘18 Camaro 2.0T, ‘67 Chevelle SS
Did you try starting it in neutral? I had a friend with a similar issue but admittedly different car. It started in neutral which indicated a bad neutral safety switch.
Southwest is offline   Reply With Quote
Old 02-27-2020, 09:12 PM   #13
Jason16ss
Its the juction box on the battery but cant find the part part number 84081785
Old 02-27-2020, 09:21 PM   #14
Trochoidal
Is this the part you need?
https://www.gmpartsdirect.com/oem-pa...block-84081785
