07-23-2021, 10:39 AM | #1 |
Drives: HBM ZLE Join Date: Aug 2017
Powering dual gauges
Asked in the electronics section with no response, wondering if I can run both my aem and aeroforce gauges off the same power? Either running it off the cigarette lighter or afm source in passenger footwell. should I run one off of each power source? Thanks for any input
07-23-2021, 10:45 AM | #2 | |
Drives: '18 ZL1 1LE Join Date: May 2020
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
07-23-2021, 10:57 AM | #3 |
Drives: 2019 Chevrolet SS Join Date: Mar 2019
Yes you can, I run it off an add a fuse off of the f42 HVAC fuse in the fuse box in the engine bay with a 5 amp fuse. the gauges dont draw much current at all.
07-23-2021, 12:16 PM | #4 |
Awesome, thanks for the responses. Should I run a fuse then to each gauge off my splices?
07-26-2021, 06:27 AM | #5 |
Master baiter
Drives: 17 NGM ZL1 Join Date: Aug 2009
You can just use an add a circuit to your fuse block and not have to splice into anything.
07-26-2021, 08:03 AM | #6 |
Good idea, thanks. I'm gonna check those out
