04-27-2021, 08:38 AM | #1 |
Drives: Camaro SLP ZL575 Join Date: Nov 2020
Rear axle problems ?
I talked to my local US car dealer here in Norway. They told me that the Camaro had problems with the rear axle of tuned cars, with a compressor, for example. Is this right ? Is this a current issue for those who have trimmed Camaros 5th gen ?
04-27-2021, 11:32 AM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
The manufacturer builds components to handle the stock vehicle. Adding power stresses those components. Some have made hundreds of passes at drag strip with the stock rearend. Some not so lucky. It’s a roll of the dice. If you can’t afford a repair you shouldn’t take the gamble. My car is stock with a compressor aka super charger and haven’t had any failures. I have put it down the drag strip but only a few times and I drive it conservatively for the most part. It sure is a lot of fun.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
04-27-2021, 12:37 PM | #3 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Manuals seem to have a higher chance of snapping axles than automatics. But like stated they are made to handle stock power any more thrown at it is always a gamble. The 1,000 hp axels seem to work great for people who are boosted.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-27-2021, 12:53 PM | #4 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I have an extra set of SS axles but shipping would be expensive.
04-27-2021, 02:01 PM | #5 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
About 4 years ago with my HP automatic, I had the lower grade GeForce axles. I was in a parking lot and as I was stopping, I decided to blip the throttle and snapped one of their axles. Since then, I have their top of the line ones that have worked well for me.
My point is, even with higher quality, in the right conditions it can still happen.
Jack Bilger
04-27-2021, 02:56 PM | #6 |
Thanks for reply
So it's drive shafts AND differential that's the weak point? |
04-27-2021, 03:16 PM | #7 |
I'm not sure that I would call either a weak point. Their are a lot of people on here that run supercharged or turbo that haven't had a problem with the stock diff or axles. It depends on what you are doing with the car.
05-30-2021, 02:05 PM | #8 |
Drives: 2011 Summit White Camaro SS (LS3) Join Date: Sep 2014
I wouldn't call them weak. Maybe just over abused or they had some manufacturing defects. Who knows. My 2011's been tuned with toque managment pretty much removed. I've got 3.91's and have beaten the crap out of it occasionally over the years with no issue. But I don't do it all the time.
Mods: Vararam intake, Solo axleback, VTC, Overkill in-car Tune, 3.91's.
05-30-2021, 02:39 PM | #9 |
Drives: 2011 Camaro SS Join Date: Jul 2019
It was early 2010 builds. Not all. There are plenty of modded cars on here running stock suspension includi g axles.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
