04-23-2021, 03:21 PM | #1 |
Drives: 2013 2SS Dusk Special Edition Join Date: Jan 2019
Rev limiter cuts on at 5k RPM after battery change
So I have a 2013 Camaro RS/SS that was built in October 2012. Today I was proactive and replaced the OEM battery. Lucky it lasted that long even on a trickle charger.
Anyway, she wont rev past 5k RPM. I did a 5 and 20 fuse pull and hoping that resolves the problem. Anyone else experienced this rev limiter issue?
2013 Dusk Special Edition 2SS/RS (1 of 205)
LS3, 6-spd w/ Hurst short shifter, navigation, sunroof, Boston Acoustics, and Borla Type-S cat back exhaust. |
04-24-2021, 10:46 AM | #2 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Are you revving it in park or in gear?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
04-24-2021, 10:58 AM | #3 |
In neutral as it's a 6 speed manual.
04-24-2021, 11:04 AM | #4 |
I think the rev limiter is set at 5000 rpm or maybe lower in neutral. So it's normal.
04-24-2021, 12:41 PM | #5 | |
Thank you!
04-24-2021, 01:36 PM | #6 |
Drives: 2010 LS Join Date: Feb 2021
Yeah, he didn't mention he was in neutral, thus the rev limiter is 5000 when not in
gear. Should be around 6200 in gear. |
04-24-2021, 07:26 PM | #7 |
^^^ this if it is still stock and no tunes were done on it to change anything.. Safety from GM...lol.
04-25-2021, 03:30 PM | #8 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
I would be quite interested in what led you to rev the engine on 5000 rpm in neutral.
Recording datalog? |
04-25-2021, 03:31 PM | #9 | |
I need to take her for a Sunday drive anyway but damn that rev limiter sucks. Almost as bad as the 1st - 4th gear under low load. But I put in the trans plug to override that crap.
04-25-2021, 04:54 PM | #10 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Why do you feel the need to over rev the engine with no load? In gear to 6200 means engine under load as in..in gear with clutch engaged and car moving. The rev limiter is all that’s saving your engine. Put it in first gear and hold it on the floor...see how long it last...report back
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
04-25-2021, 05:56 PM | #11 | |
04-25-2021, 05:59 PM | #12 | |
04-26-2021, 04:05 AM | #13 | |
Don't try your luck Skip shift only appears when you hit 2000 rpm. If it bothers you, you can turn it off not only with the plug, but also with the tuner. |
Tags |
battery, rev limiter |
