04-17-2021, 10:37 AM | #1 |
Drives: 2010ss M6 LS3 Join Date: Jun 2018
Simple quick question, LS3 oil pump purge
Good day guys, 2010 Camaro M6 ss, I changed my oil pan gasket and removed oil pickup installed new O-ring and removed oil pump spring to shim spring for bit more press.
Think oil pump would still have enough oil in it or too much air and would need purging/filling from side of block? Its tight to even see where to fill if needed. Thanks guys, didnt know who to ask.
2010 SS M6, stage 2 summit cam, CAI Intake/long tube cat delete with flow master/ZEX NOS at 150RWHP/ custom tune/MSD wires/short throw shifter/ crank vent catchcan/ SS braided brake lines/ 1.5” lower springs/bigger rear sway bar/fully poly bushings everywhere/toe arms/trail arms/front caster plates/factory shocks/steering poly inserts
04-17-2021, 10:46 AM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Hold accelerator pedal to floor and crank engine over. Engine won’t start and you prime the pump
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
04-17-2021, 10:55 AM | #3 |
GREAT idea, i never thought of that!! thanks!!!
04-17-2021, 11:25 AM | #4 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
You can also manually fill the oil pump. Which is what I do first before before priming it via other way. This ensures there is oil in the pump.
https://www.melling.com/videos/how-t...mp-by-melling/
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
