03-20-2021, 04:48 PM | #1 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
ARH ball and socket leaking
So I just finished installing ARH headers and midpipes. Etier I'm doing something wrong or this clamp sucks. I have tried different positions and it still leaks. What are my options better clamps, sealant?
03-20-2021, 05:20 PM | #2 |
Drives: 18 ZL1 mostly stock Join Date: Jan 2020
Looks like the same style joint I have on my kooks, I couldn't get them to seal worth a damn. Mine were coated so I ended up taking the coating off the mating surface but they still leaked. I used some high temp red rtv on the socket side and it stopped leaking. I actually ended up doing all the joints in my exhaust with it until I have time to tig it all up.
07 LMB Z06 Cartek 4x heads and cam, ARH, Vararam, FAST 102, NW 102
18 ZL1 M6 MTI cam, FED heads, FBO's |
03-20-2021, 05:23 PM | #3 | |
03-20-2021, 05:59 PM | #4 |
BAMF SS
Are you torqueing them to spec?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
03-20-2021, 06:09 PM | #5 |
03-20-2021, 06:11 PM | #6 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Welcome to the club. I have the ARH Headers going into their long system. I'm on my 3rd set of clamps. Actually installed them today. I am using exhaust seal wrap around the joint. Much better than before. It was so bad I was seeing it in my wideband reading. You would think for that kind of money it would be a better fit. I am tempted to have it welded and use the connection to the x pipe be the breakaway point.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
03-20-2021, 06:23 PM | #7 |
Forgot to mention that I spoke to ARH earlier this week and he said that most people don't install the system properly. He said the Headers should be lose when the exhaust system is attached to it. He followed it up by saying to tighten the exhaust from the back and work forward. At this point I'm not going thru loosening it to redo.
03-20-2021, 06:26 PM | #8 | |
03-20-2021, 06:35 PM | #9 |
Good question.. I bought jb weld high temp exhaust wrap kit. Only using 2 items from the 3 piece kit. Bought it from Autozone. Think it was $15. Believe it is good up to 1800 degrees.
03-20-2021, 07:37 PM | #10 |
I was goingvto yry this JB weld muffler seal.
03-20-2021, 08:07 PM | #11 |
Not sure if it is high enough temp rated. Permatex had some I think it is good to 2000 degrees
03-20-2021, 08:48 PM | #12 |
Drives: 2017 1SS cruiser/ 1985 Z28 racecar Join Date: Nov 2018
I had to crank the hell out of mine and they sealed up, I thought the clamp was going to break.
17 SS 2” ARH headers, high flow cats, and 3”X pipe into NPP, Katech ported 95 mm TB, LT2 IM, roto fab, DSX FF, Katech 160* BMR motor mounts, ATI damper, 493 RWHP
https://youtu.be/E-MDIyLtV48 |
03-20-2021, 09:26 PM | #13 |
03-20-2021, 10:41 PM | #14 |
Drives: 2017 ZL1 Join Date: Jan 2017
Mine have always leaked a little. I brillo padded them and loosened up the exhaust behind and wound up getting a "better" seal. Make sure the clamp doesn't slide out of position when tightening down.
Thread Tools | |
