Old 01-29-2021, 07:09 PM   #1
20Bluezl1
BMR motor mount feedback
So I been in the process of installing my ARH headers and I have to remove the passenger side motor mount to get them in.
My question to anyone that has used or using the BMR motor mounts with the integrated stands. Are they any good and are they worth the extra work?
Old 01-30-2021, 06:10 AM   #2
Choda
Drives: Turbo 6.2
I have them. Nice pieces. Worth it to me.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 01-30-2021, 07:25 AM   #3
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I ran them for 3 years before I sold my Camaro. As Choda said they are nice, creates more room on each side of the motor and you'll save close to 20 lbs by getting ride of the old liquid mounts.
Old 01-30-2021, 09:41 AM   #4
20Bluezl1
I was reading somewhere on here that sometimes it might give the knock sensor false reading. Can this happen snice there is less give on the motor mounts.
Old 01-30-2021, 10:05 AM   #5
pnoman
Drives: 2021 ZLE
Yes it’s possible
pnoman is offline   Reply With Quote
Old 01-31-2021, 07:19 AM   #6
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Greg, I'm curious which BMR mount configuration that you ran? MM009 or MM010 and did you run the MM006's?
driven2exceSS is offline   Reply With Quote
Old 01-31-2021, 09:05 AM   #7
20Bluezl1
I'm thinking of going with the mm010 mounts as they are saying it doesn't produce to much NVH.
Old 01-31-2021, 09:10 AM   #8
Choda
Drives: Turbo 6.2
I did MM010. its not a complete solid mount. It def more stiff than OEM but does allow some movement.
Old 01-31-2021, 11:37 AM   #9
Evansa22
Evansa22's Avatar
Drives: HBM ZLE
Is the MM009 just partial replacement? Was also thinking about going this route and not sure which would be better
Old 01-31-2021, 03:49 PM   #10
driven2exceSS
Yes basically. My understanding is MM009 utilizes the car's stock bracket(s), and replaces the heavy and plushy OEM motor mount with the aide of some "stiffer" Polyurethane Bushings. The MM010 also uses the Polyurethane Bushings, but eliminates the stock brackets all into one unit. The MM006's are to make either of those two set-ups a completely solid mount. I too am curious what route to go, should I pursue this.
I am not too concerned with NVH, as long as it doesn't cause collateral damages?
Old 01-31-2021, 03:52 PM   #11
20Bluezl1
So what I got of of all the research is the best way to go is with the mm010 mounts. That don't really think the NVH is going to be to bad. Now if you do go with the mm010 and install the solid bushing then you will probably will alot more NVH.
I'm ordering the mm010 tomorrow and hopefully get them quickly. Snice I have the headers out and everything is apart I'm ready to install the mounts.
Old 01-31-2021, 04:57 PM   #12
driven2exceSS
Sweet, should be an easy install for you. Certainly give feed back once it's all back together.
**Try and get weights of the OEM parts coming off, and BMR parts going on. ...Please
Old 01-31-2021, 05:06 PM   #13
20Bluezl1
Thumbs down
Will do and keep everyone posted as I haven't seen to much posted on them.
Old 01-31-2021, 05:54 PM   #14
Evansa22
Evansa22's Avatar
Drives: HBM ZLE
Thanks for the clarity on the different part numbers.
Interested in the weight savings and ride as well. Going to install headers soon also and will be a great time to do it. I have spl suspension parts to put on first and see if/how much the ride changes. I'm already in a 1le so I don't see it getting much stiffer
