Old 05-08-2020, 07:29 AM   #1
Chris 2018 ZL1 A10
Drives: Chevy Camaro ZL1
QuickJack BL-5000SLX or EXT?
Hi fellas,
I know either of these models will ultimately work, but does anyone who has either model wish they had gotten the other? I know we’re only talking about a 6” difference in length between the two but that could be significant for reasons I’m not aware of.
Thanks,
Chris
Chris 2018 ZL1 A10 is offline   Reply With Quote
Old 05-08-2020, 07:48 AM   #2
~Jb
~Jb's Avatar
Drives: 2018 ZLE
Seems like the go to for Gen6 is the EXT model. On my ZLE, I measured 58" between jack pads so it would seem both the SLX and EXT would work. I'm likely just going to pick up the 7000EXT to be future proof. Plus they are all on sale right now.
~Jb is offline   Reply With Quote
Old 05-08-2020, 07:55 AM   #3
Tachitup
Tachitup's Avatar
Drives: 2020 ZL1 1LE M6; previous 2018 ZL1
As there is a significant price difference between the SLX and EXT, it would be best if the SLX would work. I'm curious if a Camaro owner has found that the SLX works fine.
"Don't let the sound of your own wheels drive you crazy!"
Tachitup is offline   Reply With Quote
Old 05-08-2020, 07:56 AM   #4
FoundNemo
Drives: 2019 ZL1
Does the 7000 EXT work the same as the 5000 EXT, just with more weight capacity?
FoundNemo is offline   Reply With Quote
Old 05-08-2020, 09:28 AM   #5
dcxeternal
Drives: 2019 ZL1 1LE
I have the 5000SLX and it wont reach the recommended jack points without the EXT add-on I bought. With the EXT add-on it is just enough to reach the zl1addons jack pucks.
dcxeternal is offline   Reply With Quote
Old 05-08-2020, 10:06 AM   #6
Chris 2018 ZL1 A10
The QuickJack website has the BL-5000SLX for $1416 and $1471 for the EXT. What sale are you referring to?
Thanks,
Chris
Old 05-08-2020, 10:10 AM   #7
Chris 2018 ZL1 A10
I believe they’re basically the same except that each 7000 is 100lbs as opposed to 80lbs (each) for the 5000.
Chris
Old 05-08-2020, 10:15 AM   #8
Cleancoupe
Drives: 18 ZL1 1LE
The EXT version barley reaches the two lift points near the front & rear wheels. I’ve seen people use the regular version & use the rear lift point & the second lift point in the front. I’m uncomfortable with this because most of the weight is hanging off the front end. I have the 7000lb ext
Cleancoupe is offline   Reply With Quote
Old 05-08-2020, 10:24 AM   #9
Chris 2018 ZL1 A10
Thanks for the pics, nice wheels. I’ve seen that too and shared your concern. The car seems to be very close to the rail. I purchased the Mag Pads hoping they would provide a little more space and height. Do you think the ext version will allow this?
Thanks,
Chris
Old 05-08-2020, 10:46 AM   #10
mikem2104
mikem2104's Avatar
Drives: 18 2SS 1LE, 20 Canyon Denali
i highly recomend the SUV/truck adaptors at their lowest settings so that you can hit the lift points that a 4 post lift would use under the vehicle. i'll see if i have some pictures.
also, it may not matter but i think youre lifting in the wrong direction with your quickjack which is forcing too much weight over the nose. youve got the front at the back
Mike
Current Garage:
18' 2SS 1LE, Hyper Blue
23' GMC Canyon Denali
Previously:
20' GMC Canyon Denali
16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss)
14' Ford Edge Sport
06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada
mikem2104 is offline   Reply With Quote
Old 05-08-2020, 11:13 AM   #11
Cleancoupe
Drives: 18 ZL1 1LE
Thanks,
Chris
I have the zl1 addons jack pucks on my car & the ext just reaches them. The 7000lb version with the shortest rubber blocks barely squeezes under the front pucks.
Old 05-08-2020, 11:23 AM   #12
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I bought the BL-5000SLX at Costco for $1179, works fine on my 2020 2SS...
If you are concerned about weight being too far forward, make sure you have a full tank of gas before you lift or throw a 50# bag of sand in the trunk...
I've lifted with 1/4 tank of fuel and it still seemed very stable...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
Old 05-08-2020, 11:26 AM   #13
Cleancoupe
Drives: 18 ZL1 1LE
I have suv/truck adapters. There’s no way that is fitting under the car. My smallest blocks barley squeeze under the side skirts on the front.
Hmm I never thought of that. I’ll look into that & see if it makes a difference.
Old 05-08-2020, 11:44 AM   #14
Alain
Alain's Avatar
I have the 7000 EXT version. I share your same concern with having the front of the car unsupported.
I try using the lifting points closest to the front wheels. I typically take off the front wheels and leave the rear wheels on the car to balance the weight a bit. That is unless I’m doing brake work, like in this picture.
I would recommend getting the 7000 EXT version, why not spend the extra money on the ability to lift heavier vehicles and the flexibility to reach almost any lifting point on the car.
2018 ZL1 1LE/Red hot
