09-20-2018, 01:05 PM | #15 |
Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
Car has AC again and more boost (~2 psi). Dealership got AC belt done, but said it wasn't easy. He used a tool that didn't fit and a pry bar to work it on the AC pulley. $50 well spent. I wish I could get the 5 hours back I wasted on that SOB, belt.
On stock tune for now. Will datalog with wideband to check commanded vs actual air fuel using AFR error with HPtuners. I think the stock MAF may still be correct at the small boost increase,but think I'll hit peak torque limits that will close throttle.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
09-20-2018, 04:48 PM | #16 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
Sweet, keep us posted. My mod path is going to closely mimic yours.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
08-10-2019, 05:23 PM | #17 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Has anyone found a tool for the ac belt? I have done 100 percent of the wrenching on everything in my signature, without any significant problems, but this belt has gotten the best of me. I removed and reinstalled my original belt a couple of times, it was a piece of cake to jump it on. This new belt is a COMPLETELY different story. None of the tools i have found will fit either the engine or ac pulley. Neither have holes or spokes for the zip tie method and the damn belt is just too damn tight to start enough to jump it on.
Baby Blue
08-11-2019, 08:03 AM | #18 | |
Train Driver
2018 Camaro ZL1LE
08-11-2019, 08:54 AM | #19 |
There are a few different iterations of the "stretch fit tool". There is the semicircle type which is what Gates recommends and a wedge type. I've used the zip tie trick too but all have been a PITA. Reusing the old belt never caused as much frustration just as you guys have mentioned above. There are a few instructional videos on YouTube. One guy with a 5th gen installed an AC belt with his sunglasses on...very irritating.
08-11-2019, 09:03 AM | #20 |
This is the newest version...hopefully, "new and improved".
10-02-2019, 09:16 AM | #21 |
Drives: Turbo 6.2 Join Date: Feb 2019
im about to put a new ac belt on this weekend. I have always been able to walk them on, lets hope i can with the camaro. Do you guys work from the top of the engine bay or the bottom?
Can someone help me verify this is the correct belt. ACDelco 12685983 GM Original Equipment Air Conditioning Compressor Belt https://www.amazon.com/ACDelco-12685...evrolet+Camaro
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 Last edited by Choda; 10-02-2019 at 09:32 AM. |
10-02-2019, 04:26 PM | #22 |
That's the correct part number. Best of luck with the install, I ended up using the tool referenced in post #10. It was still a major pain.
Baby Blue
10-02-2019, 06:21 PM | #23 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Walking belts onto a pulley is a bad idea. It damages the cords in the belt and shortens it’s life.
10-02-2019, 08:28 PM | #24 |
all stretch fit belts are "walked on" one way or another...there isn't any other way with no tensioner
10-02-2019, 08:46 PM | #25 | |
Some DIYers will try and walk a non-stretch belt onto a pulley, even using a screwdriver to pry it on, rather than properly loosening the tensioning mechanism. The machines I design have belt drives and we were having belt failures in the field. Come to find some inexperienced line workers and service techs were walking belts on and damaging them. |
10-02-2019, 09:09 PM | #26 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
On this car, you have to follow the GM procedure. Put the belt on with the belt hanging off the back of the big pulley with a half twist. Turn the crank to walk the AC belt on.
You can find the GM page with these instructions on this forum.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
03-26-2020, 10:56 AM | #27 | |
Page 4 shows the twist, I just dont understand how this helps? https://www.chevrolet.com/content/da...n-12678596.pdf
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
03-26-2020, 11:18 AM | #28 | |
Baby Blue
