10-20-2014, 08:14 PM | #1 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
P1153 code
Cel on after 2 months since header install. Installed rear extenders and rear 02 sensors....question....is code p1153 from rear sensors or from a leak? Car is not tuned
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
10-20-2014, 10:45 PM | #2 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Car needs a tune, that will turn off P1153.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
