Old 06-18-2018, 05:29 PM   #435
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Originally Posted by Joe's_cool_1le View Post
No video on it?
Wow, I must of never uploaded it. Will get that up shortly.
Sledgehammer70 is offline   Reply With Quote
Old 06-18-2018, 05:35 PM   #436
Sledgehammer70
Lethal Camaro
Some new upgrades.... Finally!
With the push for power and moving to the Whipple I had upgraded my injectors to the FIC offering, but fell flat on waiting for the LFE big bore pump. Regardless, that pump is now on its way and a new cam in bound to make use of the fuel increase.
A great lesson I have learned is set your goals for bigger than you want and you will not have to buy parts again. I never dreamed going beyond my 747, but... yeah you guys know I should have known better...
We're spec'ing the cam out a bit more to the Whipple setup to pull low end torque and bring it back up top so we can launch the car and now with the converter it has changed things a bit... for the better.
So, new fuel pump, new cam and a new tune incoming. Finally get to realize all this Whipples power as the high side pump I have now while running E85 hates life when wanting to go over 780rwhp on the CMS dyno. New big bore setup and new fuel lobe will be welcome additions.
Maybe I should go 110 and avoid all these fueling issues.
Old 06-18-2018, 08:30 PM   #437
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
I thought Cunningham set your cam up for the centrifugal blower. Which is night and day different than your Whipple. I seen you mentioned it was just boost in general, but they don't really work that way. Glad to see you getting a cam to match your blower, it will certainly help with your power and your new fuel set up. Good luck on your mods!
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons
Custom cut Brian Tooley Cam
SW long tube headers
3" stainless mid pipe - Secondary Cat delete - High flow cats
Port and polished heads-Double valve springs-platinum lifters & push rods
Cam phaser limiter - DOD delete
P1SC-1 Pro Charger 3.7 pulley
Stage II intercooler
667rwhp 577ft lbs
Chevy71 is offline   Reply With Quote
Old 06-29-2018, 01:53 PM   #438
Sledgehammer70
Lethal Camaro
I've been hunting an electrical gremlin in my car the last few weekends. The issue is causing the battery to drain down to next to nothing. Everything has been unplugged that was added and now I am going to start testing fuse by fuse to see if we can find the rogue power draw.
We have replaced the battery and checked the alternator. The battery seems to cycle and will hold a charge. But 2-3 days later, dead.
We thought we figured it out, but it still plagues me.
Old 06-29-2018, 07:09 PM   #439
Gen6_1Le
Gen6_1Le's Avatar
Drives: 2018 Camaro 1Le
Do you use an exhaust bypass valve controller or electric cut outs ? maybe something goofy going on there .
Gen6_1Le is offline   Reply With Quote
Old 07-02-2018, 02:21 PM   #440
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
i glanced over the thread but i must have missed it. why did you change power-adder?
hitmix300 is offline   Reply With Quote
Old 07-03-2018, 05:00 PM   #441
Sledgehammer70
Lethal Camaro
Wanted more power down low all the time and wanted more power in general.
Old 07-03-2018, 05:01 PM   #442
Sledgehammer70
Lethal Camaro
Still waiting on the LPE big bore pump, but here are my cars current power numbers until that arrives and gets installed.
Running E85 w/ 13lbs boost - 761RWHP / 690 RWTQ
This blower has a ton more to give but being fuel system limited sucks. Looking at other options regardless of still upgrading fuel components. C16 and Meth could be in my future.
Old 07-31-2018, 01:41 PM   #443
Sledgehammer70
Lethal Camaro
Yesterday with the help of a good friend I installed my new cam and the LPE big bore fuel pump. We will now go back to the 3.5 upper and add the 9.1 lower for the Whipple and aim for the stars. Goal on the CMS dyno is 850+ and probably close to 900 on a DynoJet.
Old 07-31-2018, 03:02 PM   #444
DFW1LE
DFW1LE's Avatar
Regarding the LPE HPFP, I thought I heard it does not work or at least may result in reliability problems with cams that have fuel lobes greater than 10%. What do the experts say about this?
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 08-02-2018, 10:38 AM   #445
Sledgehammer70
Lethal Camaro
That would be for Version 1.0. Version 2.0 fixes this issue.
Old 08-02-2018, 12:53 PM   #446
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
When you do the next video could you state what your entire fuel system looks like? I've very curious to know as I'm on the fence about getting my Whipple modified for port injection.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 08-02-2018, 04:32 PM   #447
Sledgehammer70
Lethal Camaro
Sure!
Old 08-03-2018, 06:06 AM   #448
wnta1ss
Drives: 2017 Camaro 1SS
Gotta bust your balls sledge. You had a video called "Installing FIC injectors" I think it was and no part of the install was shown whatsoever. You just showed them sitting in the box.
wnta1ss is online now   Reply With Quote
