Old 09-30-2018, 10:05 PM   #1
eaglesfan2006
Drives: 2019 1SS 1LE Riverside Blue
I Used Simply Green to Clean my Wheels
I used to use simple green on my old car which had plastidip wheels. I was having trouble getting the wheels clean on my Camaro with soap and water so I sprayed them down with the simple green and with a little bit of scrubbing, they look brand new. Took about 10 minutes to clean these wheels compared to the 20-30 it normally takes me.
Is there any reason I shouldn't use simple green on my much nicer and better wheels, then my previous car?
eaglesfan2006 is offline   Reply With Quote
Old 10-01-2018, 06:53 AM   #2
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
Simple green is a bit harsh. You can dilute it with water or better yet, get some wheel cleaner from the store and try that.
Airfuel is offline   Reply With Quote
Old 10-01-2018, 08:43 AM   #3
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
Simple Green works via Sulferic Acid - Might get away with it for awhile but IMO eventually you may have some issues depending on wheel finish.
I coated my wheels when new with cQuartz and I just hit them with a foam cannon when I am washing the rest of the car and rinse
DorkMissile is offline   Reply With Quote
Old 10-01-2018, 08:49 AM   #4
eaglesfan2006
Yeah it was diluted down with water per the instructions on the bottle.
What other products work extremely well?
Old 10-01-2018, 08:51 AM   #5
eaglesfan2006
They’re the stock satin black wheels.
With the cQuartz the dust just washes right off??
Old 10-01-2018, 09:46 AM   #6
SSJ455
SSJ455's Avatar
Drives: "Kara Zor-El" 2017 2SS HBM
I use Eagle 1 AtoZ Wheel Cleaner. I have been using it for years and it works very well.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 10-01-2018, 09:47 AM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
In all honesty the Adam's polishes work amazing! All of our shop cars are cleaned with it and most car show people around here love it. Fairly decent pricing and fast shipping!
Kayla L.
801.545.4215
JDP Sales is offline   Reply With Quote
Old 10-01-2018, 11:00 AM   #8
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
They are just wheels. Clean them with the same soap you wash the car with or just get some wheel cleaner at the auto store and try it.
Many choices, don’t over think it.
If you want to get anal, go to the auto geek or autopia forums and go nuts.
Old 10-01-2018, 11:01 AM   #9
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
See the how to in my sig for the easist way ive found to keep wheels clean.
Old 10-01-2018, 11:11 AM   #10
FlowForm_Wheels
FlowForm_Wheels's Avatar
Drives: Turbo 4, SC V8 and Twin Turbo V8
Yeah you would think it's all fine and good until something like this happens - https://www.e90post.com/forums/showthread.php?t=406357
Example photo from a bad batch of wheel cleaner:
Simple Green is quite terrible for Clear Coats, I would stop immediately. PH neutral wheel cleaners are going to be better for the finish on the wheels so that the above doesn't happen to you.
I personally use this, but also Sonax as mentioned before isn't a bad choice either:
https://www.esotericcarcare.com/gyeon-q2m-iron/
https://www.esotericcarcare.com/sona...-cleaner-plus/
As a wheel manufacturer who knows, please do not use simple green on your wheels, it will deteriorate the clear coat and over time ruin the finish.
FlowForm_Wheels is offline   Reply With Quote
Old 10-01-2018, 11:20 AM   #11
Nsxmatt
Drives: 2017 Camaro
If you keep them decently clean and apply a wheel or even a regular wax, there shouldn't be any reason why soap and water won't clean them fine.
Nsxmatt is offline   Reply With Quote
Old 10-01-2018, 02:22 PM   #12
7WSM
7WSM's Avatar
Drives: 2017 ZL1 A10
Brown Royal diluted down 1:4, hosed down with a pressure washer. I never touch my wheels.
7WSM is offline   Reply With Quote
Old 10-01-2018, 06:05 PM   #13
eaglesfan2006
Wow, I had a feeling it was to easy to be true. I’ll be looking into other methods that won’t damage the wheel.
Thank you!
Old 10-01-2018, 06:06 PM   #14
eaglesfan2006
This method wasn’t cutting it. Took me 15 mins of scrubbing on each wheel. I’ll be looking into other methods to clean the wheel.
