Old 07-21-2021, 08:57 AM   #1
RED HULK
Drives: 2018 Camaro SS 1LE
Torque spec sticky?
2018 camaro 1ss 1LE
Vehicle Jack points
Front
Parking brake on with wheel chocks behind rear wheels
Lift both front sides using two floor jacks
Use magpad on hockey pucks at opening on pinch weld behind Jack pads
Place Jack stands under front Jack pads and lower
Rear
Use 2 hockey puck on Jack at black steel frame behind diff to lift entire rear at once
Place Jack stands under rear Jack pads
Lug nuts 140 ftlbs (owners manual)
Oil change
0w-40 Mobil 1 Dexos oil cap FC265 (rock auto)
0w-40 Mobil 1 supercar (amazon 2 6qts packs) car took 11qts some is left in each bottle
M12 mag drain plug (dimple) 13mm socket torqued to 18 ftlbs
Pf64 acdco filter (walmart/amazon)
Black hole filter magnet (dimple)
Oil pan had oil leak on it- removed undercovers, massive aluminum brace
ALL OIL PAN BOLTS WERE LOOSE! torqued to 18 ftlbs see link below
https://www.camaro6.com/forums/showt...il+leak&page=2
reinstalled brace to 37 ftlbs see link below
https://www.camaro6.com/forums/showthread.php?t=503222
Rear differential
Perform on level surface no lifting needed.
fill until fluid comes out of fill hole
Drain plug 55573646/fill plugs 24ft/lbs(camaro6 sticky)
Buy 2 qts dexron LS gear oil gm 88862624
Suction gun (Amazon)
Spark plugs
Spark plugs 15 ft/lbs (c7 forum)
Gm: 12622441 Acdelco: 41-114 (owners manual)
Manual transmission
manual trans drain/fill plugs 20 ft/lbs (c7 forum)
Gm manual transmission fluid 88861800 qty? (Owners manual)
Change at 45000 miles (owners manual)
Front and rear brakes
https://www.camaro6.com/forums/showt...ighlight=banjo
Front caliper to knuckle: 110ftlbs + 15-30deg+ blue thread lock
Banjo bolt: 30ftlbs + new crush washers
Bleed screw: 12-15 ftlbs
Rears Caliper to knuckle: 92 ft/lbs + BLUE thread locker
Front and Rear alignment torque specs and bolts
https://www.camaro6.com/forums/showthread.php?t=502324
Touch up paint
1LE splitter: W0848/WA848/WA08484 from TSB for ZL1 rockers
https://www.paintscratch.com/touch_u...48-WA8555.html
1LE wheels: WA784U
Front sway bar end links
36-38ft/lbs seems like an educated guess
https://www.camaro6.com/forums/showthread.php?t=489428
Coolant
Premixed dex cool
1LE takes 13.9qts
Change at 5 years or 150,000 miles
Plan to drain radiator multiple times instead of flushing system
Fill surge tank using turkey baster/funnel and cup it is open to atm and evaporates
RED HULK is offline   Reply With Quote
torque specs
