Old 06-15-2021, 07:11 PM   #1
Osbornsm
Drives: 2018 SS 1LE
My alignment slips...
I got an alignment and drove it home. The rear camber slipped making the toe off too.
I have SPL rear toe arms.
What will prevent camber slipping on those dumb eccentrics?
SPL camaro page
Thank you!
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 06-15-2021, 07:25 PM   #2
cdb95z28
cdb95z28's Avatar
Were they new camber bolts?
Old 06-15-2021, 08:31 PM   #3
Osbornsm
Drives: 2018 SS 1LE
Negative. But they're TTA, correct? So no need to replacen, from what I understand
Old 06-16-2021, 10:26 AM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
talk to turner at spl parts but pretty sure you need these also
https://www.splparts.com/products/ca...-kit-gen6.html
Old 06-17-2021, 01:56 PM   #5
cdb95z28
cdb95z28's Avatar
The service manual calls out for the bolts to be replaced as they are TTY, Torque To Yield, not Torque To Angle as you mentioned. Being TTY, they are one time use.
Check this thread out:
https://www.camaro6.com/forums/showthread.php?t=502324
Old 06-18-2021, 01:57 PM   #6
weemus
Drives: 2017 1SS 1LE
You need the SPL lock out kit along with the toe arms. The one krops linked. Mine came as a kit with both the lockout kit and arms. Zero issues.
weemus is offline   Reply With Quote
Old 06-20-2021, 08:24 PM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
+1 This
Old 06-27-2021, 12:10 PM   #8
Osbornsm
Drives: 2018 SS 1LE
Yes but we're talking about camber arms... not the toe arms.
Old 06-27-2021, 12:33 PM   #9
Stephen12ZL1
Drives: '21 ZLE A10
camber has a lockout also:
Old 06-27-2021, 04:06 PM   #10
Osbornsm
Drives: 2018 SS 1LE
