06-30-2021, 02:39 PM | #169 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I'm not trying to take anything away from the Coyote, or the thrill of going 900 rpm higher. Just saying the LT1 offers more performance ...in a different rpm range. The LT1 is a high performance feat of engineering and it has consistently beaten the Coyote in every test.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
06-30-2021, 03:48 PM | #170 | |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
I love that I don't have to rev the shit out of my car like a jackass when I want a little more power. |
06-30-2021, 07:09 PM | #171 | |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
But, the Gen 3 Coyote doesn't need to make as much torque because it has more rpms which yields similar power results with less torque. That said, given the displacement (307 c.i.) and DOHC config., 420 ft-lbs at 4600 rpm is pretty dang good. The LT1 and Gen 3 torque curves are pretty close to the same shape about 1000 rpm apart with the Coyote making less torque, but since it is shifted up the rpm band, makes about the same amount of power. The LT1 is slightly flatter in the low rpm range, with the Coyote flatter at the high rpm range - which is why the A10+Gen 3 Coyote is such a good match. It is able to utilize optimal gearing and rpms to send torque to the rear wheels. Both engines are very effective and there's more than one way to skin a cat.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
06-30-2021, 09:06 PM | #172 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
I had the first gen Cotote in my 2014 Mustang GT. Car revved quicker, and sounded good. I enjoyed ripping through the gears (though the MT-82 was weak compared to the Tremec). I learned to road race in that car. It was plenty fast, though LS and LT engine counterparts would always pull on me on the straights. The LT is also sweet, but in a different way. Lots of torque down low, but still pulls hard between 4000 and 6200. It takes longer to get through that range, with a wall of torque behind it, which is also nice. Bot engines are certainly fun though. Looking forward to track the SS 1LE in 2 weeks. Will have a better impression when I've had a chance to rev it out on track The Camaro chassis is way better though. Car is so composed and puts down power well. No excess body motions. Loving it so far. |
06-30-2021, 09:35 PM | #173 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Fun fact: Coyote goes in F-150s. So yeah, truck engine as well. It's not like there are any cars other than the Mustang using it.
And while no one races around 2k RPM, if you drive a stick and you aren't paying attention to your RPM(or are just new to the track and trying to learn it), you could dip into lower RPM band and that could be a bit more troublesome with less low-end torque. With an LT1, you could just shake it off, no biggie, but with a Coyote, it will hurt a bit more. With something like S65... Welp, there goes your lap time. Engine torque characteristics will play a role in your tracking strategies. It was actually kind of nice that I could just keep my car in 3rd at the HPDE event I attended so I could focus more on line work, braking and cornering. It's not optimal, but again, also not horrible. My main problem is with the fact that people seem to jizz over DOHC so much like it's some next-gen tech. It isn't. Real advanced engines don't need cams. I can understand people's fascination with Koenigsegg's Freevalve or FCA's Multiair, but I don't believe the former has been used in a production car and the latter still has a traditional exhaust cam. Still, Multiair is pretty cool from an engineering perspective. They were able to get rid of the throttle body with the intake valve lift, timing, and duration having so much freedom from being controlled by hydraulic pressure. And my RX-8 didn't even need valves, ha! That, and the fact that "horsepower per litre" is such a stupid metric, and this is coming from a previous rotary owner that can pretty much laugh at any NA piston engines when it comes to that. Horsepower per weight makes a lot more sense. Not perfect, but at least not as stupid as horsepower per litre.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
06-30-2021, 11:49 PM | #174 |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
Camaro SS1LE VS Mustang GT PP2, both on similar tires, this should give an idea VS the Mach1
https://youtu.be/ifaWMxS1O10
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
07-01-2021, 08:26 AM | #175 |
Drives: 21 Bronco Join Date: Jun 2012
I am very anxious to see what kind of performance the C8 Z06 can put out.
07-02-2021, 10:17 AM | #176 | |
2021 Camaro ZL1 A10
07-02-2021, 01:14 PM | #177 | |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
07-02-2021, 06:29 PM | #178 |
Ha, Thanks. Yeah, M6G has C6 beat in the forum features and usability.
2021 Camaro ZL1 A10
07-02-2021, 07:02 PM | #179 | |
Drives: like an old lady Join Date: Jun 2012
2) i guess you need to tell gm to ditch the 5.5L motor for a cummins swap. they make no tq and rev to the moon. what junk.
07-03-2021, 12:01 PM | #180 | ||
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
In the debate of high revs vs more TQ, sure a higher revving engine is a lot of fun on the highway. I love my GT for that reason. But still, nothing beats that neck snapping monster torque that my HC has. Which do I prefer? Let's just say I'm lucky to be able to have and enjoy both. Sometimes I want the torque and so I drive the HC. Other times I want to high revs so I drive the GT. Other times I want the best of everything in the best all around package so I drive the ZL1. |
08-14-2021, 05:24 AM | #181 | |
Are there any published results of Sam Strano's SS1LE VS his new Mach 1 or comments made by him comparing both cars performance?
'16 Camaro SS
08-14-2021, 08:14 AM | #182 |
I visited the Mustang6g forum, and was very pleased to find that the majority spoke very highly about the Performance for the $ of the Camaro SS1LE VS the Mustang Mach l, except for the zombie brand loyalist that we also have on this side.
What surprise me the most was the comments from Sam Strano for whom I have my strongest respect as both a professional sport car competitor driver and a very honest performance Parts seller whom he tries his own products at the track. He mentions that the performance of both of his cars, at the track: Mach l and SS1LE are very similar, but he didn't not trust the brakes of the Camaro consider them dangerous under track conditions. Is the first time that I hear this type of comments about the 6th gen Camaro's Brakes. I was surprised https://www.mustang6g.com/forums/thr....161487/page-2
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport Last edited by Bosse'sBoss; 08-14-2021 at 12:00 PM. |
Tags |
1le, comparison, mach 1, performance, price |
