03-04-2021, 06:42 AM | #1 |
Drives: Toyota Puris Join Date: Oct 2020
How to check oil pressure without gauges?
Curious to see if there is a way to check the oil pressure without the gauge pack? (Talking about the optional gauges in the center console area)
Thanks |
03-04-2021, 09:11 AM | #2 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
03-04-2021, 11:26 AM | #3 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
It is displayed on the DIC page. And as mentioned you can use a mechanical gauge. I'm currently learning my recently purchased C5 Vette with an LS3 transplant and the OP sending unit is on the AFT side of the intake manifold, drivers side. You could connect a manual gauge in that location for trouble shooting purposes.
03-04-2021, 02:17 PM | #4 | |
03-04-2021, 03:03 PM | #5 | |
Drives: 2011 Camaro SS LS3 Join Date: Oct 2020
Someone correct me if I'm wrong though. |
03-04-2021, 03:23 PM | #6 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I have a 2012 SS and don't have that menu button but have the console gauges.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-04-2021, 03:25 PM | #7 |
Nah you're right. The 2010-2013's we don't have that option in our DIC, that's why I have the Aeroforce gauges, and watch my console gauges. At least not to my knowledge.
03-04-2021, 05:14 PM | #8 |
I figured it out! I have a bluetooth OBD2 Scanner with the Torque Pro app. I input these values into the app:
You'll need to go to: Settings-Manage extra PIDs/Sensors-...-Add custom PID and enter the following values: PID: 22115c Long Name: Oil Pressure PID Short Name: Oil Pressure Minimum Value: 0 Maximum Value: 100 Scale: x1 Unit: psi Equation: (A*0.65)-17.5 OBD Header: Auto |
